having trouble with rebuilt engine
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by rearsteer70k5, Jun 29, 2003.
  1. rearsteer70k5
    rearsteer70k5 Registered Member
    Jun 28, 2003
    33
    newark,cal bay area
    it's a 350 not stock but not wild. The engine runs but it cuts out when it is idling. it's like me turning off the engine for a second then turn it back on when i havn't touched the key. all wires are hooked and nothing lose. need help with problem????
  2. Big Red
    Big Red 1/2 ton status
    Jan 9, 2003
    250
    Bristol, CT
    i have this problem, but its very rare and only when i've been driving a lot (like 4 hrs straight) i can't seem to pinpoint the problem, but i am still goin thru the routine checks. so, i'll let u knowwhat i find. But, in the meantime, check the dist (making sure its not retarded, causing the engine to eventually foul plugs and shut it down) sry i can't hel;p out more. btw, mine was just rebuilt a while back as well.
  3. big pappa b
    big pappa b 3/4 ton status
    Jan 3, 2003
    6,328
    Falcon, Colorado
    Sounds like maybe not getting enough fuel at idle. Do you have a fuel pressure guage? See what your pressure is at idle. Manual or electric pump?
  4. rearsteer70k5
    Jun 28, 2003
    33
    newark,cal bay area
    i had a 750 edlebrock carb on it before and it was running to rich and did the same thing. so changed to a smaller carb 600 edlebrock it still smells rich.
  5. Big Red
    Jan 9, 2003
    250
    Bristol, CT
    i didn't even think of fuel pressure! stupid me! that shoulda been the first thing i said to check. dert. thanks big pappa b! /forums/images/graemlins/thumb.gif
