Hazard lights not working-help!!!
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Pookster, May 8, 2001.
  1. Pookster
    Pookster 1/2 ton status
    Nov 21, 2000
    3,195
    NYC, NY, USA
    Ok, this really blows...
    So this weekend, I decide, "oh, let me double park here for a min..." so I try my hazards. Nothing. no blinking. At first I thought it was just a bulb out or something. but then, with the hzards depressesd, the turn signals also dont work.
    So then I try figiting with the different conbinations.
    seems that if I depressed the hazard half way, turn the turn signal either way, the blinker works. But , it blinks in synch with the fasten seatbelt light. This is totally driving me nuts!!!!
    Help, anyone with ideas?!?!
  2. dyeager535
    26,979
    Never had to troubleshoot something like this (imagine that! lol) but the hazards may be on a different flasher..if your panel has two flashers, or a convenience center with a flasher, try swapping them and see what happens. At least its easy..i know the cars had seperate flashers for turn signals/hazards, not sure on the trucks.
    Dorian
  3. muddin4fun
    muddin4fun 3/4 ton status
    Feb 19, 2001
    5,644
    N Texas
    I would whip out the voltameter and check for shorts. Even the fasten seat belt light blinks?! Hmmm! That's a new one! LOL! I would also replace the flasher too, just to rule that out (they're cheap anyway).
    <A target="_blank" HREF=http://k5chevyblazer.homestead.com/home.html>http://k5chevyblazer.homestead.com/home.html</A>
  4. herauf
    herauf Registered Member
    Feb 19, 2001
    18
    san jose, ca
    did you check the blinker fluid?
    (sorry to steal that line, but i couldn't resist...)
    ryan.
  5. Pugsley
    Pugsley 1/2 ton status
    Jan 16, 2001
    3,556
    Tucson, Arizona
    Depending on what year your rig is, it may have a little electronic control box mounted above the accelerator (My 85 does). On this little sub panel you'll find the horn relay, the hazard flasher, the ignition buzzer, and the little black box. If you unplug the black box it will slide right out, and the cover pops off real easy. Look in there for dirt/corrosion. Apparently this little thing is the nerve center of all electricals that really don't need a nerve center. I blew the dust and dirt out of mine, and cleaned the contacts and my hazards magically started working (after a GM tech told me it was the switch, without a doubt).
  6. 89Blazin
    89Blazin 1/2 ton status
    Mar 20, 2001
    134
    midwest KC area
    You might check the fuses.....turn signals are probably on a different fuse than the hazards....
    85 Burb and an 89 Blazer
    One just for fun, one simply for pleazer
  7. Pookster
    Nov 21, 2000
    3,195
    NYC, NY, USA
    I know, this is like the weirdest problem I've ever heard of myself. I know on imports, they use boxes for all the controls (including brakes, imagine that). I'll check above the accelerator, and use some electronic cleaner on the items you all mentioned. Its just that he "Fasten seatbelt" light comes on when you wiggle it. As the saga continues!!!!
  8. BillyBob
    BillyBob 1/2 ton status
    Feb 23, 2000
    557
    Dumont, NJ
    If it happens for no reason, it's usually a fuse. if you haven't wired anything into the blinkers, I doubt it's a short. check your fuses first.
    <A target="_blank" HREF=http://billybob.coloradok5.com>http://billybob.coloradok5.com</A>
    If it ain't leaking oil, it ain't my truck![​IMG]
