hd 10b tierod on d60?
Discussion in 'The Garage' started by muddybuddy, Oct 30, 2005.
  1. muddybuddy
    muddybuddy 3/4 ton status
    Jan 29, 2004
    8,933
    Fairfax Station VA
    i have a heaby duty tie-rod for my 10b, will it be able to work on a d60, maybe with different ends?
  2. readymix
    readymix 3/4 ton status
    May 30, 2004
    6,706
    26
    Murrieta, California
    The 10 Bolt tie rod is longer then the D60, so just cut it shorter and retap the end a little deeper.
  3. muddybuddy
    Jan 29, 2004
    8,933
    Fairfax Station VA
    any idea how much i'd need to cut off?
    thanks
  4. readymix
    May 30, 2004
    6,706
    26
    i don't remember:dunno:
  5. 85mudblazin
    85mudblazin 1/2 ton status
    Mar 26, 2004
    3,951
    Austin,TX
    Its a little longer but not much, maybe 1-2". Really depends of how tight your 10b tie rod was built. If the ends are screwed all the way in, you will have to cut some off. If they are adjusted out a good ways you will be fine.
