HD front shackle
Discussion in 'OffRoad Design' started by Mastiff, Aug 2, 2003.
  1. Mastiff
    Mastiff 1/2 ton status Premium Member
    Jul 21, 2002
    2,755
    48
    Tucson, AZ
    Can you explain what happens to the extra half inch of lengh on the shackle? Does the front end sit slightly higher, or does the shackle tilt back a little more than stock? A combination of the two? I'm just asking because I can't really picture the physics of it to predict how it works. /forums/images/graemlins/tongue.gif
    The web page mentions that it affect caster angle and may influence the amount of highway wander. It tilts the pinion down then? Funny thing is, I have a shim in there to tilt it up. But I do wander some on the highway.
  2. heavy4x4
    heavy4x4 1/2 ton status
    Aug 28, 2002
    3,270
    Delafield, Wisconsin
    Now this is an exaggeration, but for the sake of explaining, think about putting a shackle 1 foot longer than stock back there. What would happen would be that the rearmost part of the spring would be pushed downward, the pinion would be pointed downward more (caster increasing), and you would gain roughly 6" of lift. This six inches is the result of only moving one half of the front spring down 12 inches. *Disclaimer; do NOT put a shackle more than about 1-2" longer than stock in!*
    Anyway, that's basically the physics of it. With only 1/2" difference, it's not going to change caster too much and the shackle will still be relatively straight up and down. The reason for the little bit of extra length is to keep the spring eye from hitting the frame when the leaf spring flattens while stuffing a tire.
  3. Mastiff
    Jul 21, 2002
    2,755
    48
    Tucson, AZ
    Thanks, that makes sense. /forums/images/graemlins/thinking.gif
  4. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    But do you gain 1/2 a inch of lift ??? I was under the impression you do.
  5. 84k5
    84k5 1/2 ton status
    May 13, 2000
    2,949
    Dublin, CA
    You only gain half of the increase in shackle length. So in this case you get 1/4" of lift.
  6. bigjbear
    Feb 18, 2000
    13,973
    453
    Marietta GA
    If it's 1/2" longer you gain 1/4" of lift. You are only moving the mount point of one end of the spring.
