HD Oil Cooler for 89 Burb was punctured
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by KRAZIE87K5, Jun 30, 2003.
  1. KRAZIE87K5
    KRAZIE87K5 1/2 ton status
    Feb 23, 2001
    3,369
    Chicago, IL
    I pulled the one from my 89 Burb, after I primed the engine I just installed, and found that the engine oil cooler was leaking. It appears to be a B&M cooler... just like the one listed at summit racing for $109! /forums/images/graemlins/eek.gif Anyone see a problem with me trying to repair the leak in this unit I already have? Its on the side (not in the "fins"), and its between two of the segments in the cooler... I could attach pics later tonight... but for anyone thats looked at one of the B&M coolers, you would know what I mean. It looks repairable... but I REALLY don't want to risk losing an engine over the fact that my oil cooler fails. /forums/images/graemlins/angryfire.gif
    Any suggestions? Anyone out there have one of these they want to sell? /forums/images/graemlins/thumb.gif
    -Dan
  2. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    Check out this B&M cooler from Summit. part No# BMM70264. Has 1/2 " NTP fittings you can adapt anything to it.. Its what I replaced my stacked plate cooler with. It should fit no problem if you already have a B&M cooler. Its $49.95
    It also replaces the stock GM cooler exactly. Except you need adapters to NTP threads for the oil lines.
  3. KRAZIE87K5
    Feb 23, 2001
    3,369
    Chicago, IL
    GOOD CALL! Thats the one I just ordered up! /forums/images/graemlins/wink.gif Matter of fact, that looks IDENTICAL to the one that I pulled out of the truck. SO... thanks for the sweet tip! The only one I found when I looked out there was the entire engine oil cooler kit. You da man!
    -Dan
  4. Thunder
    Jul 20, 2000
    8,946
    Northeast Nevada
    Glad to help. Thats why these boards are great! /forums/images/graemlins/thumb.gif
    Save a lot of time money and hassle
  5. heavy4x4
    heavy4x4 1/2 ton status
    Aug 28, 2002
    3,270
    Delafield, Wisconsin
    Well, I wish I would have asked the same question about a month ago. /forums/images/graemlins/frown.gif /forums/images/graemlins/mad.gif /forums/images/graemlins/tongue.gif
    The oil cooler on my '90 burb sprang a leak too. I was planning on just removing the cooler and having a shop pressure test it to find the leak and then fix it. I was hoping that this would be around $30 or so. To make a long story short, I ended up twisting off the metal part of the lines removing the cooler, so I had to buy a $115 engine cooler kit. /forums/images/graemlins/eek.gif And, when I installed it, all I used was the cooler (which was the EXACT same thing as my $40 tranny cooler), the rubber hoses, and two of the fittings in the kit. (The oil filter sandwich adapter wasn't as "universal" as it said it was)
    Oh well...too late now. I didn't really have time to wait for parts though since it's my DD. /forums/images/graemlins/smirk.gif
  6. KRAZIE87K5
    Feb 23, 2001
    3,369
    Chicago, IL
    Actually, I would like to correct this thread real quick like... I got B&M P/N 70264 today, which is acutally a tranny cooler, with hose-clamp type fittings on it. /forums/images/graemlins/angryfire.gif The REAL P/N that I need is 70266, which has 1/2" NPT fittings, and is also the 3-section cooler (70266) vs. the 2 section (70264) cooler.
    I've now paid to have this correct cooler next day shipped ot me for ANOTHER $20... ah well... thats the price to play today I guess...
    Happy parts hunting folks! /forums/images/graemlins/wink.gif
