HD Shackels
Discussion in 'OffRoad Design' started by kgblazerfive, Oct 21, 2005.
  1. kgblazerfive
    kgblazerfive keymaster Premium Member GMOTM Winner
    Dec 2, 2004
    10,614
    602
    Hooper, Utah 84315
    Hey have a question kind or dumb but, If I use the new HD shackels on a four inch shackel flip will it give me 2 more or only 1 more inch of lift? I'm reffering to the six inch longer ones. Oh nother question could these also be used to lower a truck?
  2. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    We typically don't recommend using the 6" shackles with a 4" flip since you put the back of the spring way lower than the front. Depending on shackle angle, it can work, but not all the time. Usually the 2.5 flip with the 6" shackle is the way to go.
    Lift wise, the 6" shackle will give you about 1" of lift since it's 2" length. This does depend somewhat on the shackle angle.
    A 6" shackle in a stock tension shackle system will lower the vehicle about 1".
  3. PsychoticDeadGuy
    PsychoticDeadGuy 1/2 ton status
    Jan 8, 2005
    753
    Fairfield, California
    hey stephen, how much would it cost me if i wanted a pair of 7.5" long shackles to use with your 4" shackle flip. i have some home(hacked together)made shackles and they are the perfect length but i want something that is professionally made. what do you say?
  4. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    Sounds like you're a perfect candidate for our build it yourself kit. We have the parts to let you build your own tube style shackles at any length you want, the folded style are more of a production piece.
  5. PsychoticDeadGuy
    Jan 8, 2005
    753
    the build it yourself kit? i havent seen it. its for the rear tapered shackles right? i would be very interested in these. thanks.
  6. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    The "kit" I'm referring to is the collection of parts we used to build the HD rear shackles on the UAK10, it's a HD bushing assembly, length of heavy wall tube and a u-shaped spring hanger bracket, pricing is $68.00 for the pair, you cut to length and weld together.
