HD tie rod Question
Discussion in 'OffRoad Design' started by Seventy4Blazer, Jun 3, 2003.
  1. Seventy4Blazer
    Seventy4Blazer 3/4 ton status
    Apr 21, 2001
    5,634
    Escondido, CA
    ok folks, i am going x-over some day. and maybe highsteer. but if i have a problem with the zero rates and the high steer then i wont. question is this....
    -will a stock location HD tie rod from ORD work with the ORD high steer arms? or is there a length change?
    thanks a bunch.
    Grant
  2. Seventy4Blazer
    Apr 21, 2001
    5,634
    Escondido, CA
    anybody?
    Grant
  3. Greg72
    Mar 5, 2001
    15,684
    1,392
    642 Days to BB2018
    thanks a bunch.
    Grant
    56" Center-to-center measurement of stock tierod setup (D60, stock position on knuckles)
    53" Center-to-center measurement of High-Steer setup (D60 again)
    49.5" Length of actual highsteer Tie Rod (add the TRE's to get to the 53" measurement above)
    No idea what a standard ORD tie rod length is....but that should get you started.
    /forums/images/graemlins/cool.gif
  4. Seventy4Blazer
    Apr 21, 2001
    5,634
    Escondido, CA
    hmm, and i dont think they are adjustable by 3 inches total...
    bummer.
    thanks man.
    Grant
  5. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    They're quite a bit different, however, they're probably enough different that you could cut one end totally off and drill and tap it again. Or sell the rod complete and start over.
  6. Seventy4Blazer
    Apr 21, 2001
    5,634
    Escondido, CA
    bummer. not sure if i will be keeping anything steeringwise stock, so i will have to wait ethier way.
    thanks though.
    Grant
