HD Tie Rod
Discussion in 'The Garage' started by jaredmajor, Mar 16, 2006.
  1. jaredmajor
    jaredmajor Registered Member
    Mar 2, 2005
    96
    Anchorage, AK
    I got my dana 60 but it doesn't have a tie rod.:mad1: I would like to get a heavy duty one. I saw on here about rockstompers rock rod and they don't make them any more. I live up here in alaska so the closer the better. Anybody have any idea as to who makes one, or should i just get out out of a junkyard. I am going to get a x over steering but don't want to pay 800 bucks for the tie rod that goes over the springs.
  2. MTBLAZER89
    MTBLAZER89 3/4 ton status Premium Member GMOTM Winner
    Aug 14, 2001
    7,272
    237
    Oak Harbor, WA
    Give Sky a call. They sell their 60 crossover kit for $375 I believe. You just need to supply the 2wd steering box. You could add in a HD tie-rod for another $130 or so I believe.
    www.sky-manufacturing.com
  3. NorthWestFab
    NorthWestFab 1/2 ton status
    Jan 11, 2005
    311
    Canada Eh.
    We can get one up to you, we are in BC so not to far.
    Jordan
    NWF
  4. jaredmajor
    Mar 2, 2005
    96
    Anchorage, AK
    I've hear of one that was 1.75od and .5 wall thickness, is that possible for you? and how much if so?
  5. chopped&bobbed77burb
    chopped&bobbed77burb 1/2 ton status
    Oct 5, 2005
    925
    milwaukie,oregon
    I bought a bunch of 1.5 dom 1/4 wall from the local steel yard that was in the scrap pile along with some long lenghts of 1.5 dom 3/8 wall @ 28 cents a lb . I bought some threaded inserts from mad4wd ($14 each ?) and just made my own drag and steering link . I think my total cost w/ new tierod ends was around $100 . I did buy a sky arm for my cross over steering and still need to buy the other arm so I can do the hysteer but the 1.5 dom 1/4 wall has worked out pretty well in the stock location .
  6. pvfjr
    pvfjr 1/2 ton status
    Feb 10, 2004
    2,425
    Oakridge, OR
    Look for Pimp Offroad in the Vendor section. He has 1.25OD .25wall DOM, 1.5OD .375 wall DOM, and 1.75OD .5 wall DOM. Best prices I've seen too. :D
  7. MTBLAZER89
    Aug 14, 2001
    7,272
    237
    Oak Harbor, WA
    can i ask why you need a 1.75 tie rod? Tons of people have the 1.5 .25 wall and abuse them regularly. Are you ramming stuff a lot with your tie rod? Seriously though people have clearance issues with diff covers and springs with some 1.5 stuff. You must have a beefy diff cover if you need a tie rod that big so check your clearances there before you buy. Another option is just get a thin .25 walled 1.5 tie rod and run hi steer.:D
  8. jaredmajor
    Mar 2, 2005
    96
    Anchorage, AK
    I just liked the sound of 1.75x.5, but you pointed out a very good point, thanks
  9. MTBLAZER89
    Aug 14, 2001
    7,272
    237
    Oak Harbor, WA
    No problem just don't want to see people spending money needlessly:wink1: Thats what CK5 is here for.
  10. 1-ton
    Apr 17, 2004
    2,884
    161
    Las Vegas, Nevada
    I have a 1.75 OD tie rod, which uses TRE's that have a 1" diameter shank, on my truck. I got it from Sky Manufacturing a couple of years ago. Sky does not make them any more (I think) because many of the major manufactures (like Moog) discontinued the 1" shank left hand thread TRE, and also Sky probably decided there really is no real need for a tie rod this large. There are clearance issues with this size tie rod. You will not be able to put a beefy aftermarket diff cover on your truck, and you will have to remove one end of the tie rod every time you want to change the front diff gear oil.
