Head games
Discussion in 'The Garage' started by neverendingproject, Aug 29, 2005.
  1. neverendingproject
    neverendingproject 1/2 ton status
    Jul 24, 2005
    1,637
    Tulsa, OK
    I am in the process of building a 383 torque monster with vortec heads. In this process, I found that one of my cylinder heads has a big crack in the middle water passage stopping right before it goes between the two middle combustion chambers. I am in college so I dont have a whole lot of money so I was wondering if it would be worth it to get it fixed or should I get a new head? If I can fix it, can the local machine shop fix it or am i going to have to send it to someone who specializes in welding cast iron?
  2. sandawgk5
    sandawgk5 3/4 ton status
    Oct 28, 2003
    6,881
    Kitsap County PACNORWEST
    Dont quote me on this but I think once it is cracked your done. I have never heard being able to safely repair a cracked head.
    Ira
  3. chulisohombre
    chulisohombre 1/2 ton status
    Apr 11, 2002
    4,141
    14
    Bangor,Pa
    once its cracked it is scrap metal.get a new head.they are pretty cheap.only a couple hundred bucks. problem is as it heats up it expands and cools and contracts.if you weld it to fix it it will not hold effectively as far as i know.
