Head gasket, or head itself???
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 89GMCSuburban, Aug 26, 2002.
  1. 89GMCSuburban
    89GMCSuburban 1/2 ton status
    Nov 15, 2001
    3,005
    Thornton, CO
    I have a problem with my truck consuming coolant. It takes about a gallon every two weeks. If I start the truck cold and run it for about 30 seconds, shut it off and pop the radiator cap, there's pressure that needs to be released. That shouldn't happen unless it's hot. It starts to overheat, but it cools very quickly once I start moving or I hold the engine at higher revs. No problems overheating while at constant speed. Bubbles come to the top of the radiator while running, but there's no horrid white smoke out the pipes and there's no water in the oil. What the hell is going on????
  2. twenty_below0
    twenty_below0 1/2 ton status
    May 16, 2001
    436
    Haines, Alaska ...u.s.
    I had an early 80's Camaro that had a similar problem, ended up being the head gasket, did you check compression on all cylinders to compare them? Might not be your problem but I think it's a good place to start....I'm sure someone with more knowledge than me will chime in here pretty soon. good luck /forums/images/icons/grin.gif
