head gasket
Discussion in 'The Garage' started by 93h22cvc, Jun 25, 2006.
  1. 93h22cvc
    93h22cvc Registered Member
    May 3, 2005
    23
    milford ct
    whats up guys. i was driving home tonight and noticed my 88 k5 puffing white smoke out of the exhaust. when i got home there was coolant leaking from one of the exhaust leaks in my y pipe. so my guess is the head gasket. are they a pain in the a$$ to change. i have only done head gaskets on import 4 cylinders with overhead cams. it has a 5.7 tbi motor.
  2. JEBSR
    JEBSR 1/2 ton status
    Dec 23, 2004
    1,541
    Clarksville, TN
    It's easier in my opinion. No timming belts or chains to deal with. Pull accesories that bolt to the heads, Pull the intake,exhaust and then the heads.
  3. 93h22cvc
    May 3, 2005
    23
    milford ct
    is it possible that it is just the intake manifold gaskets? . the oily is not milky.the truck didnt overheat. and it still runs fine.
  4. kd7kmp
    kd7kmp Registered Member
    Jun 2, 2004
    99
    Springivlle, Utah
    It's possible. The only way to tell is to perfrom a compression/leakdown test. That will also tell you what cylinder is giving you the problem. Either way the intake manifold has to come off.
    Kevin
  5. 93h22cvc
    May 3, 2005
    23
    milford ct
    i actually just got the intake off. the gaskets are all there. not broken or anything. idont know. looks like it is probrably going to be head gaskets.
  6. JEBSR
    Dec 23, 2004
    1,541
    Clarksville, TN
    Intake gasket can leak water into the oil and make it milky, but cant run into the cylinders causing smoke.
  7. 93h22cvc
    May 3, 2005
    23
    milford ct
    so its probrably head gaskets?
  8. 93h22cvc
    May 3, 2005
    23
    milford ct
    i forgot to mention. when the truck was at idle it was'nt smoking. only after it idled for a minute, like at a light, and then i gave it gas it would smoke pretty bad and then clear up until it slowed down for a minute again. thanks for any info
  9. Scott A
    Scott A 1/2 ton status
    Apr 18, 2002
    129
    Monrovia, CA
    I have the exact same problem: http://coloradok5.com/forums/showthread.php?t=178746
    Looks like it's head gasket time for both of us :p:
  10. 93h22cvc
    May 3, 2005
    23
    milford ct
    sorry i forgot to follow up. it was the head gasket. i changed it everything ok
