Head gaskets on a 2.8? are they a pain?
Discussion in 'The Garage' started by y5mgisi, Apr 22, 2006.
  1. y5mgisi
    y5mgisi 1 ton status
    Aug 11, 2002
    17,156
    247
    Portland Oregon
    I have to do a head gasket on a budys s-10 Do they suck to do any more than say a 350? or are they easyer? any tips on what to plan ahead for?
  2. bigbluesuburban
    bigbluesuburban 1/2 ton status
    Feb 8, 2006
    1,362
    Constant State of Perpetual Anger
    They aren't too bad.
    If I remember correctly there are a couple 'hidden' bolts in the lifter valley. But don't quote me on that.
    You know what the best fix for blown head gaskets on a 2.8 is... Install a 4.3... I have done it, TWICE.
    Good Luck
  3. y5mgisi
    Aug 11, 2002
    17,156
    247
    Portland Oregon
    really? ive heard that it is an enormous pain in the @$$ to do that swap. Got a place where i can get more info?
  4. 4X4HIGH
    Dec 14, 2001
    22,062
    69
    Pleasanton, CA.
    The only way you went from a 60* V/6 to a 90* V/6 is by changing tranny's also.
  5. Drey
    Drey 3/4 ton status
    May 8, 2003
    8,288
    Iowa
    a 3.4 V6 out of a camaro is a straight swap in place of a 2.8 if i remember correctly. No transmission swap needed.
  6. Bushido
    Bushido Registered Member
    Jan 25, 2006
    38
    Hawaii
    Just a little heads up(pun intended):rolleyes: .The intake gaskets on the 2.8s leak making the oil and water mix making it look like a blown head gasket.Might want to check that,could save you some time if that's the case.---If it is a blown head gasket, replacement pretty straight forward.
  7. tarussell
    tarussell 1/2 ton status
    Dec 28, 2002
    1,354
    Bagdad , FL
    X2 !
    Make damn sure what is wrong first or you might end up doing a lot of extra work that was not needed.
    If your buddy's S-10 is a 4x4 than it will make getting at the exhaust ( driver's side ) flanges more difficult but other than that it is just the standard stuff as far as motor work goes.
    HTH , Tom
  8. y5mgisi
    Aug 11, 2002
    17,156
    247
    Portland Oregon
    ok cool deal. Thanks for the tips and the heads up about the intake gaskets leaking I gotta head out there today yippie!
  9. R77K10
    R77K10 Banned
    Mar 15, 2006
    564
    Lincoln IL
    4.3 have their fair share of problems too
    i kow alot of 2.8L that run excellent no issues, and i own one such 2.8 right now that i drive daily, 98k miles and counting
    good luck
  10. bigbluesuburban
    Feb 8, 2006
    1,362
    That is absolutely correct.
    We stuck with the same tranny model... 700R4... and the tranny mounts were the same. This was on a 2wd version so T-case was not an issue. The driveline bolted up perfectly and the truck was better for it.
    Thanks for the clarification
  11. bigbluesuburban
    Feb 8, 2006
    1,362
    The first swap I did WAY BACK WHEN was a hot rod swap. I made many many mistakes and it was bit of a PIA. I took parts from different trucks and changed to a carb over FI and blah blah blah blah. In the end it was a cool little truck. But I do not think that I would do it that way again.
    The second one that I did was a completly different animal. This guy wanted to keep it a daily driver. We picked up a smashed truck from an auction. It was a low mileage 4.3 in a total loss truck. But we got everything. Wiring harness, accessories, computer, etc etc etc. We pealed the truck away from the 4.3, removed the 2.8 setup, and then took our time to install the 4.3. It was 3 weekends of solid work but the power and dependability was increased exponentially on the little S-Truck.
    For those of you with 'Miracle 2.8's' that have no problems and 200K on them. Good for you. But I have had a couple of 2.8 S-Trucks & Blazers and all were pigs.
    For me the 4.3 is the only way to go.
    EDIT: In an little S-Truck or Toyota... not in my Sub... LOL
  12. beater74
    beater74 1/2 ton status
    May 29, 2001
    1,749
    atlanta
    the 2.8 i had years ago couldn't even get out of it's own way.
  13. Drey
    Drey 3/4 ton status
    May 8, 2003
    8,288
    Iowa
    The S10 i drove in highschool was a 2.8, 5 speed 2wd. not real speedy off the line but you could whinde her up pretty tight. all i ever broke on the truck was a clutch and about 6 or 8 back tires...funny thing though I never hand to replace the front tires...
  14. onetonbb74
    onetonbb74 1/2 ton status
    Dec 1, 2005
    2,083
    Campbell, CA
    i had a 83 s10 153,000 miles and it had the 'no balls' 2.8 and got 19 mpg's and its nickname was the exxon Valdez. I hated it, leaked oil so bad i got pulled over for it a couple of times. Now i have a 80 yota and it has 2x the mileage and way more power and its a 2.2l that gets 23mpg's and leaks very little oil. The only thing i did to that 2.8L was put 30k on it in 6 months, changed the fuel pump, and rebuilt the carb. Pretty reliable but 4 cylinders smoked it bad.
  15. Slapperbar
    Slapperbar Retired Navy NDT Examiner Premium Member
    Nov 29, 2005
    2,747
    3
    Harrison City, Pennsylvania
    We had an '88 Celebrity with the 2.8 and it had well over 220,000 miles on it. Still ticking, the trans was sheeit thou.
  16. 3 on the tree
    3 on the tree 1/2 ton status
    Oct 16, 2004
    3,970
    gunnison colorado
    Almost, but not quite. I did this swap in my Cherokee. Had top change the front cover and oil pan, to clear the crossmember. Also, 3.4 has no provision for a mech fuel pump, so I had to install an electric pump. The biggest difference is balance. One is internal balance, like a 350, and the other is external balance, like a 400. Cannot interchange flexplates/flywheels, unless you like vibration. The 3.4 in my Cherokee gets better mileage than the 2.8 ever did, and it is a lot quicker, also.
  17. scrappyk5
    scrappyk5 1/2 ton status
    Mar 17, 2002
    2,099
    virginia
    XXXX3 .
    i know mine had the same problem but the motor was soo worn out , i just swapped over a 3.4 crate motor. pretty easy swap, only issues was a little fuel starvation in the mid range.
  18. theperfectgarage
    theperfectgarage 1/2 ton status
    Oct 5, 2005
    988
    tucson arizona
    I did the 3.4 swap in my wifes cherokee about 3 years ago, used the GM performance parts 3.4 crate engine. I run a edelbrock intake, a holley 390 cfm carb, a msd 6a ign. box and I put a trans go shift kit in it. The swap is basic but I did have to custom balance the flex plate. It's a good swap.
