Head Gaskets - Re- use?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by unsane, Nov 19, 2002.
  1. unsane
    unsane Guest
    Well my crankshaft is toast. Just ordered a new Scat Crankshaft from Northern Autoparts today. My Question however is this: Can I pull the heads(which I already installed before I trashed the crank) to install the new crank and re-use the head gaskets? The engine has not been ran at all. Some people have said its ok others have said no way! I am just running low on cash now with this new crank, and dont want to buy new head gaskets if they are not needed. Any help would be appreciated as always. Thanks -Eric Oh yeah ive got some .010 main and rod bearings slightly used(installed but never run) someone on this board can have em.
  2. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    dude its not worth the risk just get new ones they are not that much $$$
  3. jjlaughner
    jjlaughner 3/4 ton status
    Jan 12, 2001
    7,406
    Indiana
    HEY, another Indiana guy! I'm in Frankfort, just south-east of you in Lafayette.
    I'd just buy new they cant be that much, once you tighten them down then release pressure by taking them off I would say they they may not reseal correctly? I dont know, I've popped the heads off a couple vehicles but I used new gaskets going back together. If you need a hand, drop me a line.
  4. ratlover
    ratlover 1/2 ton status
    Aug 5, 2002
    215
    Peorial IL
    Well if its a low compression mild motor with iron heads you should be ok. I mean.....whats the worse that can happen if you pop a headgasket??? Best case you start blowing compression into the cooling system and you just put new gaskets on, worse case you start dumping water into the cylinder and hydrolock your motor bending rods wasting a crank and windowing your block /forums/images/graemlins/crazy.gif. Weight your risks and make your own decision......but with a low perf app you should be ok.
    Edit: Look at my sig /forums/images/graemlins/deal.gif.....I have drove my truck for about 200 miles with a poped gasket /forums/images/graemlins/shocked.gif but its a 305 that I could care less about and it was either drive it home and risk puking the motor and calling a tow or calling a tow right off the bat. Guess which way my cheap ass went /forums/images/graemlins/rolleyes.gif
  5. bigmack
    bigmack 1/2 ton status
    Jan 3, 2002
    478
    Tennessee
    I would buy new ones, it would be a real PITA to get it all put back together with the used head gakets only to find out you should have got new ones.
  6. JoseK5
    JoseK5 Registered Member
    Dec 12, 2001
    62
    Lebanon
    Once the gasket has been compressed, its used. Change it, its cheaper.
  7. 4X4HIGH
    Dec 14, 2001
    22,058
    69
    Pleasanton, CA.
    Ok, here is your answer from an automotive machinist. It depends on what type head gasket you have. If it is not the steel shim type but rather a fel-pro style gasket then you could reuse them as long as they did not tear anywhere when they came off. You also should torque them 5 lbs. higher than you previously torqued them the first time so that they actually crush a taste bit more to make them seal properly. Now my recommendation is why take the chance? It is easier to spend a few more dollars now than to have to tear it apart later which will ultimately cost you more money and time than doing it now.
  8. unsane
    unsane Guest
    ANyone wanna buy some head gaskets?
  9. TX Mudder
    TX Mudder 1/2 ton status
    Jul 10, 2000
    2,514
    Houston
    Don't reuse them.
    -- Mike
