Head Gaskets
Discussion in 'The Garage' started by tenderfoot1877, Oct 1, 2006.
  1. tenderfoot1877
    tenderfoot1877 Registered Member
    Apr 10, 2005
    13
    San Antonio
    does the intake have to come off the change head gaskets on a 350 small block? If someone has a detailed discription on the head gasket job, that would be appreciated. [​IMG]
    __________________
    6" rough country lift
    35/12.50/r15
    15" MT's
    4:56's baby [​IMG]
  2. skidpan
    skidpan 1/2 ton status
    Sep 21, 2005
    226
    SOCAL
    it may be possible, but it would be easier just removing the damn thing.. why wouldnt you want to remove the intake?
  3. ryoken
    Jun 13, 2003
    29,624
    1,380
    Jersey Shore
    It's not possible.. The intake is bolted to the heads...
  4. tenderfoot1877
    Apr 10, 2005
    13
    San Antonio
    just because I dont want to mess with taking off the distributor and I dont want to mess with timing
  5. tenderfoot1877
    Apr 10, 2005
    13
    San Antonio
    but cant I take the bolts out of the intake to pull the heads just leaving the intake where it is?
  6. NoReGrEtS
    NoReGrEtS 1/2 ton status
    Nov 7, 2005
    848
    Moreno Valley,SO CAL
    your are going to have to tare the whole top end of the motor apart
    Its not hard to do, just make sure you mark you distributor so you can just drop it back in.
    pick up a Chilton's manual it has all the torque specs you need
  7. NoReGrEtS
    Nov 7, 2005
    848
    no it wedges in between the heads
  8. ryoken
    Jun 13, 2003
    29,624
    1,380
    Jersey Shore
    Not to mention there wont be any bolts holding the intake down at that point... And you couldn't get a new intake gasket in and get the heads back over the dowels..
    Boy, this is really silly... If your willing to do head gaskets, but not a dizzy...
    Make sure you've got a torque wrench and do the headbolts in the right sequence...
  9. 1985_K5_Silverado
    1985_K5_Silverado 1/2 ton status
    Dec 21, 2005
    984
    Corn Country
    Once you see the top end of the engine disassembled, live and in person (which I'm guessing you havent ever done yet), you'll see why leaving the intake on and removing either or both heads can't be done.
    Also, consider that engines don't usually come apart as easily and cleanly as they do on the TV shows, where everything happens in 22 minutes and works great (unless you're "Jesse James" and just leave stuff unfinished anyway).
