Head gaskets?
Discussion in '1982-Present GM Diesel' started by doubleaught, Nov 27, 2001.
  1. doubleaught
    doubleaught Registered Member
    Nov 3, 2001
    14
    Lakewood, CO
    I just bought a Banks turbo setup for my 6.2. My engine has around 200K miles on it, uses little oil and runs real strong. The salesman at Banks told me I should replace my head gaskets because, "The extra cylinder pressure created by the boost will blow out your old ones." So I'm thinking I'll just buy a set and keep them on hand in case he turns out to be right. I personally like Fel-Pro gaskets (it's all I use), are they the best for this engine? Should I go ahead and change them when I do the turbo or wait and see if they go bad?
    <font color=red>When in doubt, empty the magazine.</font color=red>
    1983 K5 Blazer Silverado, 6.2L Diesel, 700-r4, D44 front, 14-bolt FF rear, 37x12.5x16.5 SSRs
  2. Oblin Goblin
    Oblin Goblin 1/2 ton status
    Apr 30, 2000
    205
    Davis, CA
    I replaced mine before installing the turbo. If your not too concerned about blowing a head gasket at an inconvient time you could just wait, but with 200k on the original head gaskets it probly won't take long. When you do replace them I would use head gaskets for a 6.5L factory turbo diesel. They'll fit just like gaskets for a 6.2 but they're reinforced to handle a turbo.
    Good luck
  3. Tybee
    Tybee 1/2 ton status
    Mar 25, 2001
    1,565
    Centennial, CO
    I did mine about a year ago, if it aint broke dont fix it. But then again dont have a turbo
    1984 GMC Jimmy 379 diesel, 700R4, 3.73s, 31x10.50 x 15
  4. Danno
    Danno 1/2 ton status
    Aug 4, 2001
    487
    Rockford, IL
    Hey! Can you keep notes on your turbo install? I've also got a 6.2L that is in dire need of more air (crazy altitude), and this might be a summer project for me.
    Technical writeup? I know I'd really appreciate it!
    1984 K5 Blazer 4x4 Silverado
    6.2L diesel, 700R4, 3.42 gears, 31x10.5" tires
  5. doubleaught
    Nov 3, 2001
    14
    Lakewood, CO
    I plan on doing a web page about the install, but it won't be any time soon. There are a couple of other things I need to fix before I do the turbo. Like the frame crack behind my steering box...
    I guess I'll just do it right the first time and do the head gaskets. It will be easier to do it when I have part of the engine taken apart anyway, than to wait until a week (or whatever) after I put it all together and take it all back apart.
    1983 K5 Blazer Silverado, 6.2L Diesel, 700R4, D44 front, 14-bolt FF rear, 37x12.5x16.5 SSRs
