Head Lamp problem on my 70 K5
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by ED70K5, Aug 25, 2000.
  1. ED70K5
    ED70K5 1/2 ton status
    Apr 28, 2000
    179
    Texas, USA
    My head lamps are both not working, so I went out and bought new ones and there still dead. The two lamps in the middle of my grill are both working after I replaced the bulbs. Where should I go from here??? Need help guys/gals..................need to pass inspection!!!
    Blazin' in TEXAS!
  2. 70jimmy
    70jimmy 3/4 ton status Premium Member GMOTM Winner
    Mar 3, 2000
    5,956
    249
    Released from Pueblo, told I belong in Southpark
    Dimmer Switch? Switch from low to high beam and see if they light up. If so its the dimmer. Also check the headlight switch. From there wiring YUCK! Good luck
  3. ED70K5
    Apr 28, 2000
    179
    Texas, USA
    Which one is the dimmer switch?? I know this sounds stupid, but I barely took my rig out of storage a couple of months ago.
    Blazin' in TEXAS!
  4. ED70K5
    Apr 28, 2000
    179
    Texas, USA
    Upon investigation I found the "dimmer" switch on the floor board!!!!!! I feel so stupid!!! I clicked it and my headlights came on!! They only work in one setting, though. At least I have head lamps! What now??? Do I have to replace the dimmer switch????
    Blazin' in TEXAS!
  5. Dieselmh
    Dieselmh 1/2 ton status
    910
    Texas
    Get a test light or voltmeter and start checking for voltage at the on/off switch. Keep going towards the lights until you lose voltage. This will show you where the broken wire/switch/relay/etc. Good luck.
    Diesel
    If it ain't broke, fix it 'til it is.[​IMG]
  6. 70jimmy
    Mar 3, 2000
    5,956
    249
    Replace the dimmer switch. 2 bolts. Just lift up the carpet, unplug the wiring and install the new one. Cost about $6.00 for me. I had same thing happen and since I hate wiring i took a chance and replace mine. Bingo.
  7. ED70K5
    Apr 28, 2000
    179
    Texas, USA
    Sounds like a plan!!! I'm gonna try it first thing in the morning!
    Blazin' in TEXAS!
  8. ED70K5
    Apr 28, 2000
    179
    Texas, USA
    BINGO! It was the dimmer switch! THANKS GUYS!
    Blazin' in TEXAS!
  9. Bigmeats
    Bigmeats 1/2 ton status
    Jul 29, 2000
    523
    Manhattan IL
    Another problem solved thanks to this site. We should all pay homage to Steve! :)
    Bigmeats
    Carl...75 Blazer...Manhattan IL
