head torquing
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by chevysrule, Sep 5, 2002.
  1. chevysrule
    chevysrule Registered Member
    Dec 16, 2001
    39
    Utah
    can anyone tell me the torqing sequence for cylinder heads on SBC's. I'm a first time engine builder gettin redy to put a 383 in my truck. thanks for the help
  2. heavy4x4
    heavy4x4 1/2 ton status
    Aug 28, 2002
    3,270
    Delafield, Wisconsin
    I'll leave the torque sequence diagram to someone with a scanner (because it would be nearly impossible to describe with words and still have it make sense). What I can tell you is that the torque figure is 65ft lbs on SBC heads.
    I suggest you go out and buy yourself a manual for your truck. I have both Haynes and Chilton. Chilton is the best, but Haynes is only about $15 and still very helpful. I know Haynes has the sequences, and I believe Chilton does too (I don't have that book with me at college so I'm not positive).
  3. OneInTheSun
    OneInTheSun 1/2 ton status
    160
    Pittsburgh, PA
    If you haven't done so already, get one of those "How to Build a Chevy Motor"-type books. All of 'em have good info (diagrams, torque specs). A picture for the head sequence is alot easier to go by than a description. It's recommended to start at 25 ft. lbs. and go at 20 ft. lb. increments until you hit 65.
  4. FastBanshee
    FastBanshee Registered Member
    Aug 16, 2002
    17
    San Diego, CA
  5. chevysrule
    Dec 16, 2001
    39
    Utah
    thanks again for all the help.
