Header bolt question...
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Hoss, Dec 31, 2001.
  1. Hoss
    Hoss Registered Member
    Oct 7, 2001
    41
    Seattle, WA
    I was going to go replace the header gaskets on my 82 surburban, but the bolts are so damn close to the pipes, that I can't even get a socket or box end wrench around the bolt. I can use the open end, but I can tell I'll just strip the crap out of the bolts.
    I have no idea how the previous owner got to them. Has anyone else had this problem? How did you get around it?
    Thanks!
    -C
    <a target="_blank" href=http://www.theonespot.com/myrides/suburban>1982 K20 Silverado Suburban</a>
  2. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    I had that problem with a set of Cyclone AR-1 headers. It was a real PITA to turn the bolts. They were just too close to the tubes. I ended up replacing all of the bolts with socket cap bolts. They took a 5/16's allen wrench to install. I then used a Bhondus ball driver (it's an allen wrench that works at weird angles) to install the bolts. A 5/16's wrench can be slipped over the allen wrench to provide extra torque. Worked like a champ! [​IMG]
  3. Hoss
    Oct 7, 2001
    41
    Seattle, WA
    Ahh, good idea! I need to get me some of those allen head bolts.
    How did you get the orginal bolts off? A friend suggested grinding the caps off and once the header is pulled back, I should be able to remove the bolts shaft with pliers, but I'm unsure about doing this. Not even sure if I could get the grinder close enough on some of them.
    -C
  4. HarryH3
    May 31, 2000
    10,384
    Georgetown, TX
    Got 'em off with VERY slow work using an open end wrench. Lots of slipping, cussing and banged knuckles. [​IMG]
  5. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Simple modification to your header tubes is all that's necessary. Put a screwdriver between the tubes and the bolt and hit it a few times with a hammer. I can get a box-end wrench around every single one of my header bolts now!!!
    Tim
  6. Lonnie
    Lonnie 1/2 ton status
    Dec 5, 2001
    138
    Pittsburgh, PA
    Even better than the Allen head bolts are the small 12 point bolts. ARP makes them with a 5/16" head. These clear almost everything &amp; do not exhibit the interference caused by the allen wrench hitting the tube if it curves coming out of the motor (generally the bolts at the rear of the front 2 cylinders).
    Lonnie
  7. HarryH3
    May 31, 2000
    10,384
    Georgetown, TX
    Couldn't do that with the headers that I had. The Cyclone AR-1's had flared ends and a short tube that came out of the flange, into the flare. The AR stood for Anti-Reversionary, the idea being that the tube inside of the inverted flare helped keep exhaust pulses from flowing back into the cylinder at low RPM's. I guess the idea didn't catch on [​IMG] since I haven't seen them for sale in many years.
  8. HarryH3
    May 31, 2000
    10,384
    Georgetown, TX
    That's what is so cool about the ball-end allen wrenches. They work up to about a 25 degree angle. The wrench doesn't have to go straight into the bolt head. [​IMG]
