header bolt torque
Discussion in 'The Garage' started by cegusman, Nov 5, 2004.
  1. cegusman
    cegusman 3/4 ton status
    Apr 25, 2001
    6,793
    Houston/Katy, Tx
    What do you torque header bolts to? Motor is a SB 400 if that matters
  2. kyser_soze
    kyser_soze 1/2 ton status
    Sep 4, 2004
    3,180
    KC Missouri
    20 ft. lbs. Right out of the chiltons manual for a 1971-1978 SB 400 /forums/images/graemlins/thumb.gif This was for exhaust manifolds not headers but should be the same. Remember this is a cold engine torque, warm up the motor then re-tighten. /forums/images/graemlins/waytogo.gif
  3. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    tight as i could get it with a wrench, then check after a day, they are still tight /forums/images/graemlins/woot.gif
  4. Rolled
    Rolled 1/2 ton status
    Jun 16, 2002
    683
    Anchorage, Alaska
    My dad bought some, pretty slick, header bolts. They have an allan head screw in the center that you tighten and it spreads the bolt just enought to lock em in the head. No more header bolts coming loose!
