Header & Exhaust recommendations please
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by furdaddy, Apr 23, 2004.
  1. furdaddy
    furdaddy Registered Member
    Feb 25, 2004
    27
    Phoenix, Arizona
    I've been having backfiring problems with my '74 K5 lately, which blew up the brand new muffler. I think part of the problem is the huge crack in the exhaust manifold pulling oxygen into the exhaust stream.
    So, next week I'll be having headers installed. The motor is a crate 350, 2bbl carb, not sure of any more details than that. Any recommendations on what to get header-wise?
    At the same time, I think I'll have the two auxiliary gas tanks removed to make way for dual side exhausts. Any thought on the pros and cons of this concept?
    Any muffler advice?
    What about having a crossover installed just behind the collectors? Worthwhile?
    Thanks for your words of wisdom,
    Jason
  2. BlazerGuy
    BlazerGuy 3/4 ton status
    Apr 20, 2000
    9,206
    abcde
    Why not do it yourself, it ain't that hard. Duals are a waste of money IMO. Unless you require duals(big HP mill) don't get them. /forums/images/graemlins/grin.gif
  3. K5Chris
    K5Chris 1/2 ton status
    Mar 11, 2002
    805
    New Orleans, LA
    i have dynomax ceramic coated headers, true 2.25" duals, 2 magnaflow cats, and 2 flowmaster 40's with dumps. i love it. an H-pipe behind the headers will improve your low end, and an X-pipe will improve mid-high end. i'd reccomend staying with 2.25" pipes if yer going dual, unless you want more high end, then, get 2.5". flowmasters will give you great low end and a nice loud deep tone. magnaflows will give you better high end, but arent as loud, and dont have the flowmaster tone. if your going with flows or magnaflow, order them from performancepeddler on ebay, they are cheap.
    p.s. and yes, my tbi 350 IS a big HP mill /forums/images/graemlins/rotfl.gif
    NOT!..... but, i do know for a fact that the headers/duals improved both my low end and the high end.
  4. furdaddy
    Feb 25, 2004
    27
    Phoenix, Arizona
    Because I have the money to have it done, but not the time, tools or know-how to do it myself. Plus, I'd rather spend my weekends wheeling, not working.
    Thanks for the advice on the duals. So people just get 'em for coolness' sake?
  5. mrk5
    Apr 20, 2004
    12,341
    1,047
    Northern Colorado
    I actually posted a question about Thorley Headers on the Garage forum. I'm getting quite a few positive comments about them. As noted there, they are pricy, but it sounds like maybe they're worth it. /forums/images/graemlins/thumb.gif
  6. fjleiter
    fjleiter 1/2 ton status
    Feb 13, 2004
    278
    Palmyra, NY
    Not to mention if you run a single exhaust with 3" pipe it will flow more a 2.25" pipe (area of a 2.5" pipe is only 3.9" while area of a 3" pipe is 7") which puts you close to the 7.8" of a dual setup but removes the necessity of crossover and extra muffler etc...
  7. K5Chris
    Mar 11, 2002
    805
    New Orleans, LA
    i like my duals because i do not have a cross-over. it all goes straight back, and puts both banks at equal lengths, rather than have one bank go straight back, and the other having to cross-over.
  8. rjfguitar
    Aug 28, 2002
    9,097
    144
    california
    Ive had both a single exhaust setup and my current Hooker long tube headers, 2.5" pipe, dual 40 series flowmasters, and dual 5" tips. No crossover. Both with my built 406 and I can tell you that I gained more power from my current dual setup. I don't run catalyctic converters either and it sounds extremely aggressive and very loud at WOT.
  9. Paxx
    Paxx 1/2 ton status
    Feb 9, 2003
    1,405
    All Over Western Canada
    The point to running true duals is that it is the only way to completely tuck your exhaust up and out of the way of eveything. If you run single or even add a cross-over pipe the y-pipe or cross-over will be a low hanging point on your rig. When it gets smashed up on a rock you can bet it won't flow as well as a dual set-up.
    You can have the cross-over behind your tranny/t-case but it should be as close to your collectors as possible so in my opinion it becomes fairly pointless.
  10. socalblazer
    socalblazer 1/2 ton status
    Mar 18, 2004
    110
    Redondo Beach, CA
    I just added a new exhaust to my 75 and ran dual 2" into a single 3" using a single 3" big block Flowmaster. It sounds really good, but not too loud. Low end power is better but high end dropped off a little. I stuck to the stock exhaust manifolds to prevent any gasket leak/starter/AC bracket issues; all things to be considered if changing from stock to headers. Works great for me! Good luck
  11. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    I would go with Thorley TRI-Y's and 2.25" dual exhaust with Flowmasters. /forums/images/graemlins/deal.gif
