header flange ?'s
Discussion in 'The Garage' started by MUDNUTT, Sep 6, 2003.
  1. MUDNUTT
    MUDNUTT 1/2 ton status
    Aug 1, 2001
    339
    Mn
    header flange ?\'s
    anyone ever use these. [​IMG]. im tired of replacing collector gaskets and now its time for new exhaust as the flange on one of my pipes broke /forums/images/graemlins/angryfire.gif. not sure if i'll go this route as their 45 dollars from summit, just looking for something different.
    deck /forums/images/graemlins/usaflag.gif /forums/images/graemlins/k5.gif
  2. cybrfire
    Dec 15, 2002
    15,139
    565
    Iowa
    Re: header flange ?\'s
    I have heard of guys using donuts in the collector and it working good. I have what they call dead soft aluminum gaskets. Kinda pricy but they won't ever wear out. I have also in the past cut the collector back and welded on a neck down peice of tubing to use a standard exhaust clamp. One thing I have wanted to try is to cut the header collector off and install two bolt flanges on each side so you end up with 6 bolts to hold the two together. I think that is the biggest problem with this design. 3 bolts just doesn't cut it. Just some ideas for ya.
  3. Beast388
    Beast388 1/2 ton status
    Nov 6, 2001
    3,039
    Clinton, IA USA
    I have always wanted to try those in a header application. That is a pretty successful factory design that is used quite often in OEM exhausts. I bet they would work well. /forums/images/graemlins/thumb.gif
  4. MUDNUTT
    Aug 1, 2001
    339
    Mn
    i'd like to try them i just dont know if im willing to pay $45 to. same with mufflers. when i redo my exhaust i'd like to run some 40 or 50 series flowmasters but theres no way i'm paying $80 for 1 muffler!
  5. SUBFAN
    SUBFAN 1/2 ton status
    Mar 23, 2003
    2,334
    Davenport, Ia
    Look at one in person, you may change your mind....
  6. dyeager535
    26,979
    What are those called/who are they made by? Went to look them up, can't find them.
    Was pondering asking a header company (such as Thorley) if these could be added to a header as it was being produced.
    Anyone know why these aren't used more commonly? (IE on new headers) Increased restriction because of the design?
  7. MUDNUTT
    Aug 1, 2001
    339
    Mn
    they are made by flowmaster. on their web site as "header collector ball flange kit" for $77. summit has them for $45.
  8. BowtieRed
    Dec 31, 2002
    1,776
    Winston-Salem, NC
    How about two for $60? I have some for sale if you are interested PM me. They are 2.5 in/out 40s
  9. MUDNUTT
    Aug 1, 2001
    339
    Mn
    you have mail!
