header gaskets, Aluminum, copper, or ball flange?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by xnoahx, Feb 17, 2002.
  1. xnoahx
    xnoahx 1/2 ton status
    Oct 12, 2000
    817
    Ventura, CA 93004
    Whats the better gasket for the header collector? Aluminum or copper, summit sells both for the same price($10) and has about the same description for both. I was also checking out the new flowmaster header collector ball flange kit that replaces the old triangular 3 hole one with a two bolt ball falnge that is supposed to seal much better for around $45 through summit.
    My 73 K5 <a target="_blank" href=http://www.geocities.com/xk5blazerx/73k5.htm>http://www.geocities.com/xk5blazerx/73k5.htm</a> 350/TH350/NP203, Edelbrock intake & carb, Vortec heads, 4" lift, and 36" TSL's
  2. Seventy4Blazer
    Seventy4Blazer 3/4 ton status
    Apr 21, 2001
    5,634
    Escondido, CA
    i dont know about the new ball flange, but i do know copper swells better under heat, and i love my header gaskits up top.
    Grant
    1974 Chevy Blazer Cheyanne. but it is on 33's now, with saggy old springs. i am in Yuma Arizona if ya got any parts for me.
  3. DesertDueler
    DesertDueler 1/2 ton status
    May 23, 2001
    3,106
    Phoenix, AZ
    The rwo bolt ball flange is a much better design than the old 3 bolt design. Look at all you stock exhaust manifolds, they use the baal flange, along with all shorty headders. We do alot of Mustang exhausts at work and all the aftermarket companys use the ball flange with then and none leak and you can take them apart and not have to worry about gaskets.
    86Jimmy 4"&35"MTRs,87 burb 4"&33"MT,69Firebird w/525 hp,and 70GTO live in PHX,AZ<a target="_blank" href=http://www.geocities.com/modifierperformance>My vehicles</a>
  4. Seventy4Blazer
    Apr 21, 2001
    5,634
    Escondido, CA
    good point
    Grant
  5. slider
    slider 1/2 ton status
    May 7, 2001
    547
    Whidbey Is. Washington
    Hey DesertDueler does anyone sell a ball flange that you can weld to an existing header? I am asking because I have a good set of headers I would love to retro fit to this style attaching my pipes. You must install exhaust systems.
  6. reddog64
    reddog64 1/2 ton status
    Nov 9, 2000
    3,325
    Federal Way, Washington
    no...no...no... you have it all wrong... they all blow out...
    WELD THEM TOGETHER.......
    Header straight to the pipes!!!
    I havent had a problem yet...
  7. mudober
    mudober Registered Member
    Feb 19, 2002
    23
    when I entered a mudbog once with the aluimin gaskets they got so hot they melted and ran out like butter
  8. shane74
    shane74 1/2 ton status
    Feb 12, 2002
    4,100
    Vancouver, WA
    Go with the copper if $$ is a concern. They are the only ones I've ever had any luck with.
  9. xnoahx
    Oct 12, 2000
    817
    Ventura, CA 93004
    I think im going to go for the ball flange collectors. Seems like the best way to get rid of leaks once and for all
