Header gaskets
Discussion in 'The Garage' started by Muddytazz, Mar 27, 2004.
  1. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    What are you all using for the flange gasket?
  2. bablazer73
    bablazer73 1/2 ton status
    Apr 4, 2000
    3,363
    upstate ny
    I usually use either the real good felpro's Or the O.E.M. felpro manifold gaskets with the steel shim.
  3. jakeslim
    jakeslim 1/2 ton status
    Sep 18, 2002
    2,686
    Napa, CA
    after installing the aluminum header gaskets and seeing a nice improvement in seal, I will install the same in the flanges....sometime this year
    THESE ONES
  4. k20
    k20 3/4 ton status
    Sep 9, 2001
    5,068
    Mineral Springs, NC
    I use copper in the flange and at the collector.
  5. redneck60164
    redneck60164 1/2 ton status
    Mar 18, 2003
    101
    il
    use the alum. ones after i have put them in i haven't had any more leaks. also they are resuable i am on my second set of headers first set of gaskets.
  6. alaskanbowtie
    alaskanbowtie 1/2 ton status
    Feb 15, 2004
    112
    ALASKA
    I agree Percy's Aluminum 2 years now for both heads and collector excellent investment!! /forums/images/graemlins/waytogo.gif
  7. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    I use Mr. Gasket ultra seal, but I think I'm going to have to go to a copper collector gasket or something.
  8. rjfguitar
    Aug 28, 2002
    9,095
    144
    california
    I run the Percy's alums....good gaskets.
  9. 85scottsdale
    85scottsdale 1/2 ton status
    Dec 22, 2003
    283
    Lewisville, NC
    Running summit copper collector gaskets and Mr. gasket ultra seals on the other end and no leaks so far.
  10. lukebaby1
    lukebaby1 1/2 ton status
    Dec 16, 2003
    231
    Richmond, Virginia
    Earl's pressure master.
  11. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
  12. fortcollinsram
    fortcollinsram 1/2 ton status
    Nov 8, 2001
    2,261
    Fort Collins, CO
    Percy's Dead-soft aluminum gasket on the header and the collectors...awesome gasket...
    Chris
  13. K1Orion
    K1Orion 1/2 ton status
    Jan 8, 2003
    812
    st.louis,MO
    I used the aluminum ones, Percy I think, on the collectors. I just used the ones that came with the headers for the connection at the head.
    FYI, if you have cheap headers like me and my friends do and are having problems getting em to seal, try these tricks:
    If the collector flange is not part of the collector, weld it to the collector. It prevents the flange from distorting and letting the gasket blow out. I've even been able to use the crappy paper gaskets that come with the headers with success after welding the flange on and having a reducer that is solid. The set of Hooker Pro-comp headers I had came with the flange welded but they were a little more $$$ than the summit specials I have on this truck.
    If you can't get the gaskets to seal at the head, try cutting /forums/images/graemlins/hack.gif the flange so each tube is seperate. On a SBC, obviously the the 2 center tubes will be together but the front and rear tubes will be seperate. This allows each tube's flange to seal independently, which seems to work better. My buddy has a motor with Dart angle plug aluminum heads and he couldn't get em to seal at all and was blowing gaskets all the time. After we cut the flanges on his Hedman headers it sealed up nicely and it even made the bolts go in easier. Now he has no problems with the white Mr. Gasket header gaskets from Autozone.
    Just a few tricks that worked for me and my friends. /forums/images/graemlins/thumb.gif
