header gaskets
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by K5Buckeye, Aug 20, 2001.
  1. K5Buckeye
    K5Buckeye Registered Member
    Mar 5, 2001
    75
    WA
    Picked up some new header gaskets for my 72. They were square. But, the header and the block are oval. So, went back to Jegs, they did not have any oval shaped gaskets. Only round and squares. Can't find any ovals locally. What can I do?
    The headers are Dynomax ceramic and the motor is stock, Goodwrench.
    1972 K5
    1991 Jimmy
  2. CaptCrunch
    CaptCrunch 1/2 ton status
    Feb 2, 2001
    3,596
    Minnesota
    Back when I had dynomaxs i got a Fel-Pro gasket that worked fine. Have no clue what the part number was. Try calling Dynomax... they should have a list of part numbers for various manufacture s that work w/ the header
    -Mikey
    1987 Chevy K5 Blazer- 350 TBI
    <a target="_blank" href=http://coloradok5.com/gallery/captcrunch>http://coloradok5.com/gallery/captcrunch</a>
  3. CaptCrunch
    Feb 2, 2001
    3,596
    Minnesota
    -Mikey
  4. Rob 85K5
    Rob 85K5 1/2 ton status GMOTM Winner
    1,487
    Pensacola, Florida
    Is the port on the block more of a D shape with the radius toward the top? If so than it is a "D" port head and you won't find headers that match up to it for a truck. I got a set of 1-5/8" primaries which cover the port completely and gaskets to match. The gasket will cover the prt in some areas, but you can set teh gaskets on the head and open them up to the port size if you want to.
    Rob 85K5
    <font color=orange>Bleedin' Chevy Orange</font color=orange><P ID="edit"><FONT class="small">Edited by Rob 85K5 on 08/20/01 02:17 PM.</FONT></P>
  5. K5Buckeye
    Mar 5, 2001
    75
    WA
    "Call Dynomax"....., why didn't I think of that.
    The ports on the block are oval. I wish they were D shaped b/c I remember seeing those at Jegs.
    Thanks fellas.
    1972 K5
    1991 Jimmy
  6. K5Buckeye
    Mar 5, 2001
    75
    WA
    How about a regular exhaust gasket from chevy or napa. Any major disadvantage?
    1972 K5
    1991 Jimmy
