Header Gaskets
Discussion in 'The Garage' started by BlackDog714, Jan 26, 2003.
  1. BlackDog714
    BlackDog714 1/2 ton status
    Jun 8, 2002
    260
    Indiana
    What are the best header gaskets? I used the white FelPro manafold gaskets that blew out in 2 weeks. I went to local autoparts store and they said the best ones were the MrGasket copper header gaskets for $50 /forums/images/graemlins/eek.gif.
    Is there any special ones I should be looking for?
    BTW, 454 and DynoMax coated headers. Thanks for helping!
  2. bablazer73
    bablazer73 1/2 ton status
    Apr 4, 2000
    3,363
    upstate ny
    I have always used the fel pro gaskets. Never had one burn out. I would check your header flanges. They might be warped causing gasket failure. If they are warped, sometimes you can file them straight. You gotta be carful when you tighten them up, sometimes you can bend the flanges by overtightening the bolts.
  3. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    i wouldn't skimp.
    I went through 2 sets of header and collector gaskets before i bit the bullet and bought some Percy Dead Soft Aluminum gaskets, and no leaks. worked like a charm.
  4. chulisohombre
    chulisohombre 1/2 ton status
    Apr 11, 2002
    4,140
    14
    Bangor,Pa
    i use doubled ROL high performance gaskets.they are metal and compress to fit tight when you tighten the header bolts.i have them singled for my collector gaskets.had them on for a year with no blowouts. /forums/images/graemlins/smile.gif /forums/images/graemlins/smile.gif
  5. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
  6. BlackDog714
    Jun 8, 2002
    260
    Indiana
    OK, so I have copper, aluminum and composite. What are the pluses and minuses of these?
  7. milspecjimmy
    milspecjimmy 1/2 ton status
    Aug 28, 2002
    901
    raymond, maine
    ive used em all, and never had a problem as long as i check and re-TQ the bolts after a few hours of running, then after a day. the heat on the bolts, and the cooling off make them back out.
  8. sjeccles
    sjeccles Registered Member
    May 13, 2001
    27
    Iowa
    Copper /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif
    only way to go
  9. big pappa b
    big pappa b 3/4 ton status
    Jan 3, 2003
    6,328
    Falcon, Colorado
    I have used regular exhaust manifold gaskets with good success. They are really cheap too
  10. yellowK20
    yellowK20 Well Lubricated Premium Member GMOTM Winner
    Dec 26, 2002
    7,602
    554
    Wasilla AK,
    Stock Manifold gaskets work just aswell as the copper ones and aren't nearly the cost of cheap paper header gaskets Of course if your Headers suck no Gasket is gonna seal them up but I heard dynomax is pretty good /forums/images/graemlins/truck.gif
  11. MJB774X
    MJB774X 1/2 ton status
    Sep 26, 2002
    574
    SO CAL
    use the black ones by mr gasket, make sure you re tighten the bolts several times after heating and cooling, gaskets have moisture in them and shrink up so its important to check the tightness a few times after putting new ones on, don't use silicone either, if you have to sometimes I glue two together and that works well /forums/images/graemlins/usaflag.gif
  12. BlackDog714
    Jun 8, 2002
    260
    Indiana
    Yeah, I just saw the MrGasket black gaskets too. The guy doing the work said to get the Victor gaskets or copper gaskets.
    /forums/images/graemlins/mad.gif I hate this, I just want them to be quiet!
  13. bigmack
    bigmack 1/2 ton status
    Jan 3, 2002
    478
    Tennessee
    I have had the best luck out of the some that I got at Autozone, they are also black and IIRC they are called Ultra Seal. They may be made by Mr.Gasket, but I can't say for sure.
  14. BlackDog714
    Jun 8, 2002
    260
    Indiana
    You know what REALLY pisses me off? /forums/images/graemlins/angryfire.gif I followed the instructions for the install to the T. No where did it say you need to heat cycle them and re-torque. This may be common knowledge and I may be a moron for not knowing that is necessary, but damn it shouldnt that be on the damned instructions?????
  15. MJB774X
    Sep 26, 2002
    574
    SO CAL
    yeh those are the ones, I used to have a 64 c10, I bought all kinds of gaskets, turns out the $15.00 ones from autozone work the best /forums/images/graemlins/thumb.gif
  16. MJB774X
    Sep 26, 2002
    574
    SO CAL
    put new ones on, sometimes the hard way is the best way to learn, I didn't know about re tightening until I was told by someone myself, believe me I went threw a sh!t load of gaskets and those black ones are the best for sure /forums/images/graemlins/usaflag.gif
  17. Emmettology 101
    May 9, 2000
    8,126
    FL
    I have had good luck with the PErcys ALum. ones in mine. GOing on 3 years and I haven't touched them. *knock on wood*
  18. MJB774X
    Sep 26, 2002
    574
    SO CAL
    pricey but I heard those work well too /forums/images/graemlins/usaflag.gif
