Header help....
Discussion in 'The Garage' started by ryoken, Nov 19, 2004.
  1. ryoken
    Jun 13, 2003
    29,624
    1,380
    Jersey Shore
    since i'm about to do motor mounts (and they are trashed /forums/images/graemlins/blush.gif) and a trans mount, i've decided to go for my new exhaust too.. hella easier to do em both at once...
    anyways, i'm header shopping.... i want something pretty highend and durable. figuring in the 400 to 600 range. thick flanges and a killer finish... i was even thinking of stainless, but from what i saw that might be outta my range a bit.
    i had originally just figured on Thorleys, but now i'm also considering some ceramic Hooker super comps.. will the ceramic hold up??? they have em with A.I.R too, which i wanna keep. i like the idea of a full length, i'd like as much bottom end as possible and the tri-y's aren't quite as good from what i read.
    not concerned with the ground clearance of a full length or even a little tweaking at the shackle bolt, but i'm wondering if the Thorley's are a neater install and farther away from the starter?
    also, when looking up app's for the tri-y's i saw they have 2 different apps, one stock height and one 4 to 6" lift? thats a prob maybe cuz i wont be ready for axles and lift till next summer... i wonder what the dif is... /forums/images/graemlins/thinking.gif
    btw, i'm planning on 2 1/2" duals with a crossover, some high flow cats and 50's probably....
  2. SUBFAN
    SUBFAN 1/2 ton status
    Mar 23, 2003
    2,334
    Davenport, Ia
    Hooker Headers are all I buy....I put PN 2453 on my Burb and they fit sweet.
    I would buy a black set, and if they fit and everything is fine, send them out to be coated. Keep the old exhaust manifolds around in case you rebuild that motor.
    Don't even screw with the supplied gaskets, and get a good set from the get go. Otherwise you will be replacing them soon anyways....
  3. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    To my understanding, the Thorley Tri-Y's are some of the best Headers you can get for the full size Chevy trucks. Summit carries them.
  4. ryoken
    Jun 13, 2003
    29,624
    1,380
    Jersey Shore
