Header hitting driveshaft
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by FL84K5, Aug 24, 2002.
  1. FL84K5
    FL84K5 1/2 ton status
    Aug 19, 2001
    936
    Sarasota, FL
    The guy that built my engine also put the headers on. Not sure what brand they are. They work fine on the street, but as soon as the suspesnion flexes, the front driveshaft hits one of the tubes. It's already bent the tube in some. Are there different headers for 4 wheel drives so this dosnt happen?
  2. 4x4Freak
    4x4Freak 1/2 ton status
    Apr 21, 2002
    792
    Lubbock, TX
    Most companies usually have a different listing for 4wd trucks. It's possible that the ones you have are for a car or 2wd truck. My front driveshaft rubs the collecter clamp but it's not really much of a problem, they are the cheap flowtech headers but are the right listing for my truck.
  3. Shaggy
    Shaggy 3/4 ton status
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> Mine's been rubbing for 3 years, but hasn't caused any problems. If it's isn't rubbing real hard don't worry about it. </font color>
  4. 55Willy
    55Willy 3/4 ton status
    Jun 2, 2001
    9,946
    Keizer, Or
    my 79 had heddman hedders on it. they tuck up higher then any header i have seen on a truck.. but with no lift i found out they do touch the front diff. but with a 4" when i had it ( i sold it with no lift on it) it was fine.
