header install (warm air intake???)
Discussion in 'The Garage' started by mccomas, Mar 7, 2004.
  1. mccomas
    mccomas 1/2 ton status
    May 30, 2003
    262
    Fayetteville, NC
    what does this do and what do i do with it when i install my headers? the headers are long tube hedmans with AIR and i will be installing cats.
  2. bablazer73
    bablazer73 1/2 ton status
    Apr 4, 2000
    3,363
    upstate ny
    Re: header install
    It's a stupid valve thats supposed to restrict exaust and keep the heat in the manifold so the heat riser for warm air intake can work. But usually they just rattle, cause exaust restrictions for heat risers that don't usually work anyways!!
  3. mccomas
    May 30, 2003
    262
    Fayetteville, NC
    Re: header install
    ok - so it is no big deal if i remove it, plug the vacuum line and just install a hot air kit for the headers???
  4. bablazer73
    Apr 4, 2000
    3,363
    upstate ny
    Re: header install
    Yeah, Some of the header companies make a kit.
  5. dyeager535
    26,975
    Re: header install
    Yes, you can remove it, as long as no visual emissions inspection.
    It's designed to force hot exhaust back through the intake when the engine is cold, to speed up how fast the engine warms up, especially the carb. Removing it will just (perhaps) slow this down. I doubt you'll even notice.
    This is different than THERMAC, the hot air kits companies sell are for that. The valve you posted the pic of is EFE.
  6. BlazerGuy
    BlazerGuy 3/4 ton status
    Apr 20, 2000
    9,206
    abcde
    I tossed mine in da trash....takes a little longer to warm up in the winter now.... /forums/images/graemlins/doah.gif
