Header installation on a '88 K5
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by trailblzr76, Jul 12, 2002.
  1. trailblzr76
    trailblzr76 Newbie
    Jul 12, 2002
    Header installation on a \'88 K5
    Hey all,
    I was wondering if there were any known problems with putting headers on a '88 K5. My main concern is that it will bother the computer if I take away the catalytic converter and install dual flowmasters. Any ideas??
    I currently have the stock exhaust installed.
  2. big d
    big d 1/2 ton status
    Oct 24, 2001
    1,236
    illinois
    Re: Header installation on a \'88 K5
    far as i know, none. you may want to tap in your o2 sensor back in your exhaust so your service engine soon lite isnt coming on, plus this may cause you to run ritch or to lean. other than that i think you have no conerns. my neighbor ripped off all his air cleaner crap and put on a chromey one and then put on SIDE PIPES ! (91' blazer) /forums/images/icons/shocked.gif /forums/images/icons/wink.gif /forums/images/icons/grin.gif an boy does it look smooth ! he reports no problems.
  3. jc71355
    jc71355 1/2 ton status
    Jan 13, 2002
    830
    Port Neches, Texas
    I have Dyno-Max headers and their 2 1/4 dual exhaust into two Flowmaster 40 series. I have no problems with exception to the O2 sensor problem that i'm having which doesn't happen to everyone from what i've read. You will not mess up the computer by doing this. I had to remove the Diff housing bump stop to put mine on. I also had to go to a shorter oil filter after i burned a hole in the one that was on there /forums/images/icons/tongue.gif . I have heard to disconect the battery to reset the computer after you do something like this but I could be wrong. Hope this helps.
    James
  4. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    I have headers, no cat, and single 3" pipe. on my 89. NO computer problems.
  5. 1979Jimmy
    1979Jimmy 1/2 ton status
    Nov 14, 2001
    696
    Danville Ca
    YOU CAN ALWAYS WELD A FITTING FOR AN O2 SENSOR.
  6. trailblazer87
    trailblazer87 1/2 ton status
    Jun 11, 2002
    707
    Madera, CA
    The only time you would have a computer problem is if you have an OBD-II(sp?) computer from the mid nineties trucks, anything pre-94 is safe to mess with the exhaust on /forums/images/icons/wink.gif.
    I run with open headers at times and have no problems on my '87, I did have to weld in a fitting for an 02 sensor but that was it /forums/images/icons/grin.gif
  7. Rebel88
    Rebel88 1/2 ton status
    Sep 7, 2000
    1,855
    Richmond, VA
    any problems with your oil filter?
    Later
