header question
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Bhintz, Jul 22, 2003.
  1. Bhintz
    Bhintz 1/2 ton status
    Mar 28, 2003
    1,341
    Roswell, Ga
    this is kinda dumb question but Im about to buy some headers more than likely hooker comps. but at summit w/ a.i.r. injection the price is $320 painted black and w/out a.i.r. is $150 painted black, my question is, is the a.i.r injection a little metal tube that goes into the header and if its do I need it b/c I dont want to pay the extra 170 for it if I can ditch it.
  2. Calclips
    Calclips 1/2 ton status
    Apr 4, 2001
    1,005
    Swartz Creek, Michigan/Flint while in school
    I don't come from an emissions state, so I don't know for sure, but I think that the A.I.R is an emission system and if your originally equipped with it and don't have it you might not pass emissions in your state. (That is if Georgia does all that emissions BS)
  3. 75-K5
    75-K5 3/4 ton status
    Apr 28, 2002
    5,353
    Anderson, Indiana
    I think that little metal tube is the oxygen sensor if I'm visualizing it correctly. Does it have a wire attached to it?
  4. Bhintz
    Mar 28, 2003
    1,341
    Roswell, Ga
    its not the oxygen sensor I know what that is, its a metal tube about 1/2 in diameter that runs in the header right were the exhaust runs out of the head, thens goes straight back and around the engine
  5. TONYP
    TONYP 1/2 ton status
    Aug 13, 2002
    2,116
    so cal
    a good muffler shop should be able to add those on for you, call around and see what they would charge for it.
    Good luck...I bought a set of Doug Thorleys used for $100.00 with the air and ox senser on them..
  6. BlazerGuy
    BlazerGuy 3/4 ton status
    Apr 20, 2000
    9,206
    abcde
    Yep those tubes are the AIR injection. You will need them to pass inspection if your county has emissions inspections(visual or dyno)...
  7. Bhintz
    Mar 28, 2003
    1,341
    Roswell, Ga
    will it run fine w/ out it besides not pass emissions
  8. Mastiff
    Mastiff 1/2 ton status Premium Member
    Jul 21, 2002
    2,755
    48
    Tucson, AZ
    Yeah, it'll run better. /forums/images/graemlins/grin.gif
    When I moved out of CA I ripped all that crap off and it was like a whole new truck!
  9. camiswelding
    camiswelding 1/2 ton status
    May 25, 2003
    2,545
    Redding, CA
    Im jealous mastiff... I just spent hours and hours hooking it all up just to do a five minute test.... only three more times then Ill never have to put it on again.. Ill be a classic!!!
