Headers and H-pipe
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 84K5cedric, Aug 13, 2002.
  1. 84K5cedric
    84K5cedric 1/2 ton status
    Aug 2, 2002
    279
    Austin, TX 78660
    I know short tube headers would maintain the most torque, but what would the damage be if I were to pick up some long tube headers that have 3" collectors and reduce the pipes to 2 1/2" true dual? Would I be better off sticking with the stock manifolds? The headers I may be able to pick up cheap can be seen here. And while we're on the subject, has anyone any suggestions on a non-obtrusive H-pipe? BTW, the motor is a 400sb in stock form (though not stock to the truck).
  2. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    a good muffler shop ( has big greasy guys working at it ) should be able to hook you up with an h pipe that doesnt get in the way, it should give good torque. it also fine tunes the sound to great mellow but hot sound.
  3. 84K5cedric
    Aug 2, 2002
    279
    Austin, TX 78660
    So, big and greasy or will one or the other do? /forums/images/icons/tongue.gif
  4. tipoil
    tipoil 1/2 ton status
    Jul 30, 2002
    222
    canada guebec
    Since ur header have 1.5 primary u will have no problem whit low end torque .
    i've got a 400 whit all the thing that would kill low end torque(hot macanical cam/stock converter/open plenum intake/800 cfm q-jet/3.73 gear/35-12.5x15 tire/lond tube header whit 2.5 true dual whit dynomax muffler)and it pull hard from the get go!!!
    go ahed buy them u love them!!!
    Why a h pipe??????
  5. k30gambi
    k30gambi 1/2 ton status
    Dec 24, 2001
    108
    illinois
    I had them (small greasy guy) put my h-pipe about 1 1/2 feet behind the t-case angling on top of the driveshaft. I thought it turned out good and sounds good with flowmasters. /forums/images/icons/cool.gif
