headers and leaks
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by ramjet gmc, Oct 2, 2003.
  1. ramjet gmc
    ramjet gmc CK5 Staff Staff Member Moderator GMOTM Winner
    Dec 19, 2001
    3,370
    Milltown NJ 08850 NJ sucks
    i plan on puting on some headers this weekend what is the best gasket to put on to prevent leaks
  2. bryguy00b
    bryguy00b 3/4 ton status
    Apr 7, 2002
    5,587
    Rochester, N.Y
    iv heard copper or aluminumn ones. ive got aluminum and paper ones back to back on my collectors and they still leak..guess there warped or not at the right angles..cause those damn things alaways leak..i just live with it /forums/images/graemlins/smirk.gif on the heads i just put some paper mr. gasket ones on and they seem to be fine
  3. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    I've got Mr. Gasket Ultra-Seals on mine. They're the only Mr. Gasket product I'll even consider using. Somehow the left side one blew out and got all loose, I'm not sure how.
  4. Confedneck
    Confedneck 3/4 ton status
    Nov 1, 2002
    5,236
    Lehigh Acres, Florida
    whatever you use, put it together, then drive it to normal operating temps, then retorque..
  5. bpiccioni
    bpiccioni 1/2 ton status
    Aug 11, 2002
    187
    Eugene, OR
    I used to work with a guy who bought a wrench to keep in his glovebox just to constantly tighten his headers.
  6. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Oh...forgot to mention it's the collector that's loose not the flange gasket. I know all about retorquing the flange gasket.
  7. Confedneck
    Nov 1, 2002
    5,236
    i was replying to ramjet...sorry..i always just click the last post..
  8. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    No biggie, I do the same.
  9. mudjunkie 82
    mudjunkie 82 1 ton status GMOTM Winner
    Dec 27, 2002
    11,449
    Cleveland Ohio
    I double up the gaskets and a drop of loctite does wonders
  10. mojo-jojo
    mojo-jojo 1/2 ton status
    Sep 26, 2003
    101
    PGH PA
    I use early corvette exhaust manifold gaskets, easier to use because they're in 3 pieces per side. I've changed engines in the /forums/images/graemlins/burb.gif a couple of times and have always been able to re-use them. As for the collector flange check out these part numbers from summit.
    (1)FLO-15922 Kit Header Collector Ball Flange 3.5" Coll. Onto 2.5" Exhaust System $58.39 B/O
    (2)FLO-15923 Ball Flange Collector Kit, 3.5 in. Collector / 3.0 in. Exhaust, Pair $58.95
    (3) FLO-15924 Ball Flange Collector Kit, 3.0 in. Collector / 2.25 in. Exhaust, Pair $45.95
    (4)FLO-15925 Ball Flange Collector Kit, 3.0 in. Collector / 2.5 in. Exhaust, Pair $45.95
    I couldn't find pics, but it's a ball and socket fit like on cats.
  11. dyeager535
    26,979
    The Fel-Pro kit I bought for my '74 truck engine uses the same gaskets. Aluminum facing on one side, looks like paper on the other. Buddy uses those with his headers, says they seal way better than the paper ones that come with the headers. His never leak apparently.
  12. mojo-jojo
    Sep 26, 2003
    101
    PGH PA
    I tighten'em down run the engine to operating temp, let cool and tighten again, never had a problem with a leak on that end.
  13. 87BrnRsd
    87BrnRsd 1/2 ton status
    Apr 21, 2003
    2,457
    Boone, North Carolina
    I was told to run them with no gaskets, and that they would seal up better that way. This information came from a very respectable engine builder who has been building engines all of his life if anyone wanted to know.
    -Harrison
  14. WARP1
    WARP1 Registered Member
    Apr 8, 2000
    63
    Omaha, Nebraska
    Stage 8 locking header bolts work well. I use them on my car and K5.
  15. Confedneck
    Nov 1, 2002
    5,236
    stage 8 being a company? where can you get them at??
