Headers and TBI?
Discussion in 'The Garage' started by firefighter184, Dec 4, 2005.
  1. firefighter184
    firefighter184 1/2 ton status
    Apr 5, 2003
    2,763
    The Barrio
    While INTERCEPTOR has my motor out, I'm thinking of going to headers. The motor is an 89 TBI350, bored 30 over, a decent cam. I already have a pretty good Magnaflow muffler with less than 1000 miles on the Blazer. Recommendations for headers? Definitely not looking to spend much cash, but I dont want crap either. What do you guys think?
  2. Jimbo*
    Jimbo* 1/2 ton status
    Mar 8, 2005
    1,420
    roswell, new mexico
    Whatever you choose for headers, make sure you put in a three wire O2 sensor(heated), otherwise your computer will throw a bunch of different codes. :confused: Basically, the stock single wire O2 sensor doesn't get hot enough to send the proper info to the computer. I think my headers are Headman, but the different sensor made a huge difference.
    Jimbo
  3. 3rdshiftdesign
    3rdshiftdesign 1/2 ton status
    Feb 6, 2005
    259
    Bucks County, PA
    I have a single wire O2 sensor and I don't get any codes. In fact, I ran without one for a while and it would only throw a code if i was driving for a while and really hammered down on it.
  4. WhiteBurb
    WhiteBurb 1/2 ton status
    Mar 10, 2005
    307
    Louisiana
    I went with the ceramic coated dynomax headers. They look pretty darn good. They leaked at the head after a while, so I put in copper gaskets and haven't had a problem since.
    The only thing I don't like about them is how close the collector is to the spring shackles. If I were to do it again, I would go with shorties.
    Thanks for that info Jimbo, I'm going to give it a try.
  5. K5Jimmy
    K5Jimmy 1/2 ton status
    Sep 21, 2000
    1,141
    Lake Dardanelle/Logan Co, Ark
    I have ceramic Flowtechs into magnaflows on my 89...no crossover. I simply welded a bung onto the collector on the drivers side. AC Delco one wire O2...Bosch was bad right out of the box. Been that way on the old motor 7 years, works just fine on the new motor w/ 6K on it. Don't buy Bosch.
    BTW: I have to pass the rollers sniffer in my county...My 270hp TBI passed with about 1K miles on it
  6. erik59
    erik59 Registered Member
    Jun 4, 2005
    52
    Parkersburg, WV
    I got my headers for my 89 Jimmy for 87.50 from summit. I also went with the flowtech collectors that had the o2 bung in them, which where about 20 bucks. They fit well and I don't have any complaints, but then again, I only have about 2k miles on them since I put them on in June.
    Erik
  7. TruckNutzDude
    TruckNutzDude 1/2 ton status
    Mar 31, 2003
    3,532
    Agawam, MA
    I went with a set of Hedman headers since I liked the ball and socket collector they use. I welded a jamb nut on the collector for the O2 sensor. Haven't been using a 3-wire sensor, or anything but the headers for an exhaust and I get a code once in a while if I drop the hammer. I liked the way the headman's fit and they weren't too pricey. I know Auto Zone sells Flowtech headers for Chevy pickups for about $75 and they're in stock! :eek1: I had those on my last pickup and they fit good... I would reccomend using header paint on them before installing since they rust quickly (as all uncoated headers seem to do).
  8. mtrdrms
    mtrdrms 1/2 ton status
    Mar 14, 2005
    312
    Torrington, CT
    a bit pricey I know but I love my Doug thorley Tri Y headers. they fit great and they still look good 2 years later.
  9. firefighter184
    Apr 5, 2003
    2,763
    The Barrio
    So I'm guessing that shorty headers (I'll probably be going for Summit ones, I've had good luck with Summit stuff) making sure I have the appropriate 02 sensor stuff?
  10. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    Shorty headers aren't much of a performance increase. Really more of a pain than they are worth IMO. I have a set for my S10 but thats because thats all that is made for them.
    Single wire O2 won't really throw codes but it won't run right. My Burb ran night and day different after I finally installed a three wire O2 sensor. It ran GREAT and had more power after that.
  11. erik59
    Jun 4, 2005
    52
    Parkersburg, WV
    I forgot, the headers that I got for 87.50 were full length headers
    Erik
  12. drofdar
    drofdar 1/2 ton status
    Dec 7, 2003
    113
    Fresno, CA
    3 wire
    Hey, my harness has the 2 wire connector for 02. So I bought the cheaper 2 wire unit. If I do put a heated sensor on, how is it wired, without getting a new harness? Does the heat wire run off the ignition... what?
  13. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    hot wire can run to any "hot when key in on position" wire.
    The 3 wires are as follows:
    -O2 signal
    -heater power
    -heater ground
    The heater power and ground are both white wires usually. Doesn't matter which wire goes to what, you can't hook them up backwards(they work either way). Then just wire the signal wire to the stock connector. I cut the end off and soldered the signal wire to the stock O2 sensor connector then wired the power and ground for the heater seperate. Though soldering an O2 sensor wire isn't heavily recommended. It was very difficult, the wire is a steel wire I believe, its not copper, it is pretty hard to get a good solder connection on.
  14. drofdar
    Dec 7, 2003
    113
    Fresno, CA
    Thanks for the info. I'm gonna file that in case I run into performance problems.
  15. eagle mark
    eagle mark 1/2 ton status
    Nov 18, 2004
    3,289
    North Idaho!
    You should be able to run without the O2 sensor at all if calibrated correctly. They are not used in most race applications or marine applications with no problems. If they get to cool at the end of a header you just go into open loop. Which is fine at idle, then when you drive away it'll heat up and start making adjustments again.
