Headers don't work when you want to reinstall your AC
Discussion in 'The Garage' started by Cmoe, Apr 28, 2004.
  1. Cmoe
    Cmoe 1/2 ton status
    Feb 19, 2000
    2,884
    Mesa,AZ
    Headers don\'t work when you want to reinstall your AC
    Anyone have a extra set of exhaust manifolds in AZ... I need some....AC don't work to well with Headers unless your make you own Brakets
  2. TopOff
    TopOff 1/2 ton status
    Jan 16, 2002
    1,760
    Folsom, ca
    Re: Headers don\'t work when you want to reinstall your AC
    JC Whitney has header brackets for A/C mounting.
    good luck.
  3. Smitty
    Smitty 1/2 ton status
    Sep 1, 2000
    999
    Crestview, FL
    Most of the header companies sell the brackets to work with their products too.
  4. rjfguitar
    Aug 28, 2002
    9,097
    144
    california
    What seems to be the problem? I had manifolds and do have A/C with headers now and the stock bracket. The stock bracket bolts to both bolts on #1 cylinder but the "U" on the bracket wont clear the header tube(which I bet is your prob) I just torched off the back half of the "U" So only one bolt is needed to hold it in place...reused the manifold stud instead of a header bolt and bolted the bracket to the stud.
  5. scoutillac
    scoutillac 1/2 ton status
    Feb 24, 2004
    423
    Spokane, Wa.
    You wouldn't happen to have a pic of the modified bracket installed do you? I am getting ready to put headers on with the same A/C bracket and would like to see what you did.
  6. rjfguitar
    Aug 28, 2002
    9,097
    144
    california
    [​IMG] Hope you can see well enough, I can't tell because my monitor is too dark to even see the headers....can't get it adjusted right. /forums/images/graemlins/dunno.gif
  7. scoutillac
    Feb 24, 2004
    423
    Spokane, Wa.
    Bummer I can't see it either. Thanks for tryin though. I'm sure I'll figure it out. I like to think I'm not totally stupid. /forums/images/graemlins/grind.gif /forums/images/graemlins/weld.gif
  8. rjfguitar
    Aug 28, 2002
    9,097
    144
    california
    There is nothing to it. I figured it out before I even bought the headers when I was staring at the bracket visualizing it. Just hack off the back half of the bracket that bolts to the second manifold stud back.
    Something like this....
    after cutting the back half....
    My lame diagram probably didn't help. /forums/images/graemlins/histerical.gif /forums/images/graemlins/doah.gif
  9. dyeager535
    26,980
    Dunno if this will help or not, but the 4.3L trucks used a "header" on the drivers side, which has the spacer needed for AC welded to it. The one I found the weld was already broken, but it could be easily knocked off if it wasn't. Amazingly it was exactly the right length.
    I needed that spacer for my PS pump, but IIRC, AC uses the same thing, except the U that goes over the tube. I'd think any S-10 or Astro with 4.3 and AC would have what you need.
  10. Cmoe
    Cmoe 1/2 ton status
    Feb 19, 2000
    2,884
    Mesa,AZ
    Well thanks everyone, but I just found out some bad news today... Had a friend over to try to find out what the noise that started up yesterday on the way home from class. It turned out to be the #8 header tube popped it's weld to the mounting plate. That means I need a set of headers or stock exhaust manifolds.... Well there goes more money I don't have.....
  11. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    [/ QUOTE ] Can't you weld it ??
  12. Cmoe
    Cmoe 1/2 ton status
    Feb 19, 2000
    2,884
    Mesa,AZ
    No I don't have a junk head to mount the brakets onto to make sure that I don't warp or offset the mount.
  13. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    A flat surface should work, might be worth a try befor having to buy new headers. Well if you do order new headers, remember to get the spacers for the A/C. /forums/images/graemlins/deal.gif /forums/images/graemlins/thinking.gif
