Headers for my Jimmy
Discussion in 'The Garage' started by Ledzoso, Feb 26, 2005.
  1. Ledzoso
    Ledzoso Registered Member
    Feb 11, 2005
    15
    Midland, Tx
    Hello evryone,
    New to this forum!!! Great site.
    I have some questions about headers for My Jimmy. I found some Hooker headers for 73-91 blazers/jimmys/trucks. I researched the headers and found them to be right part number. I have a question about them though. The headers have some sort of ???air intake??? ports on each of the tubes. The are threaded ports located by the flanges. My stock manifolds have one port on each side. What do you do with the extra ports? can you block them if you dont use them? The part number for the headers is 02453. Thanks for your help...
  2. k5freak44
    k5freak44 1/2 ton status
    Jun 1, 2004
    2,164
    Plano, TX
    nope they are just like any other kind of header. they only have5 holes in them (assuming its for a v8) 4 where they bolt on up front and 1 3in collecter tube where the exhaust goes out. you even have to have holes drilled and tapped to put an o2 sensor on.
  3. Ledzoso
    Feb 11, 2005
    15
    Midland, Tx
    What about the threaded ports on top of each of the tubes? Is this EGR stuff?Each exhaust tube has these fittings? The manifold has one egr port???
  4. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    Those headers are for trucks with an AIR system.(Smog pump). if your truck does not have a smog pump get a set of Non AIR headers They should be cheaper. Or you can just put threaded plugs in the holes
