Headers on! BIHATCH!
Discussion in 'The Garage' started by BowtieRed, Dec 29, 2003.
  1. BowtieRed
    Dec 31, 2002
    1,776
    Winston-Salem, NC
    Took awhile and only five bolts per side right now. BUT, once i get my driveshaft back i'm goin to the exhaust shop and having them pull out the one bolt that broke off and put in the one bolt that won't go in for some reason. i'll get them to put in new gaskets as well. any thought i'd let ya'll know, and there'll be a sound clip up comparing old to new soon. WAY louder /forums/images/graemlins/laugh.gif
  2. 75-K5
    75-K5 3/4 ton status
    Apr 28, 2002
    5,353
    Anderson, Indiana
    Loud is good /forums/images/graemlins/thumb.gif
  3. BowtieRed
    Dec 31, 2002
    1,776
    Winston-Salem, NC
    YES! YES! oh it sounds cammed out at idle /forums/images/graemlins/laugh.gif
  4. bryguy00b
    bryguy00b 3/4 ton status
    Apr 7, 2002
    5,587
    Rochester, N.Y
    /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif
  5. CHEVY 4WD
    CHEVY 4WD 1/2 ton status
    May 14, 2002
    1,773
    Florida
    Chevrolet... 4x4... Headers... Loud... sounds good to me /forums/images/graemlins/thumb.gif
  6. BowtieRed
    Dec 31, 2002
    1,776
    Winston-Salem, NC
    ok- all of the paint on the headers has change to a grayish brown, except one cylinder. is it safe to assume that cylinder isn't firing properly?
    also at first i melted the positive cable to the headers, thus grounding the truck and meltiing the negative terminal on the battery. now when i drive sometimes it bogs at low RPM and high throttle, but not always- could that be electricity jumping that gap (haven't replaced the wire, YET, will today) and grounding the truck temporarily?
    one LAST question. at idle every couple seconds there is a very noticeable thud type vibration coming from the engine. could this just be a misfire?
    thanks.
  7. BowtieRed
    Dec 31, 2002
    1,776
    Winston-Salem, NC
    SONOFA!
    ok, went to replace the positive cable, took the starter off to access the solenoid- put on the wrench to remove the nut holding the cables on and the plastic holding the nut broke. the starter is new, so that should be covered by its 'lifetime warrantee' right? tha'ts just routine maintenence. advance is usually pretty good about it so i'm gonna go try. i have the worst luck.
  8. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    They'll hook you up with a new starter, relax and take it back.
  9. BowtieRed
    Dec 31, 2002
    1,776
    Winston-Salem, NC
    put the new starter in, and went to reconnect the battery- engine started to turn over. DAMMIT, what did i do? something crossing the starter terminals?
  10. CHEVY 4WD
    May 14, 2002
    1,773
    Florida
    /forums/images/graemlins/rotfl.gif sounds like somthing i would do you probably got the wires reversed i THINK the top on is for you main power(i cant rember i have a mini starter now so i cant messup /forums/images/graemlins/smile.gif)
  11. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    He just had the positive cable touching the S terminal on the starter solenoid. It's all good now.
