Headers or Manifolds Who Cares???
Discussion in 'The Garage' started by az88k5, Nov 2, 2004.
  1. az88k5
    az88k5 1/2 ton status
    Oct 14, 2004
    258
    Prescott Valley, AZ
    I put headers from my old motor on my new crate 350. Not sure what brand of headers they are. They came with the truck so I didn't really think of going with anything else. Wondering if I should put some manifolds on for reliability reasons. I will be getting new exhaust system soon. The headers have some rust on them is this a problem I should fix? Or just run'em! I have a pressure blaster I use to glass bead pool tile with. Should I glass bead refinish and Hi-temp paint my old headers, or buy manifolds? Or just run the hell out of them! /forums/images/graemlins/grind.gif /forums/images/graemlins/peace.gif
  2. surpip
    surpip 1 ton status
    Apr 7, 2004
    10,877
    sacramento ca
    The worst header will flow bwetter than the best manifolds, i would just run them, go for it /forums/images/graemlins/peace.gif
  3. az88k5
    Oct 14, 2004
    258
    Prescott Valley, AZ
    The only reason i ask is because my friend asked me why I am still running headers. I told him /forums/images/graemlins/dunno.gif they came with the truck.
  4. divorced
    divorced 3/4 ton status
    Jul 20, 2004
    5,115
    I would just run them how they are, no blasting. I don't like manifolds because of problems with the 3 studs that hold the pipe on rusting and never coming apart. Headers can make the exhaust sound cooler too /forums/images/graemlins/thumb.gif
  5. sickquad
    sickquad 1/2 ton status
    Jul 23, 2003
    785
    Ma
    I always wondered if headers would help a motor run cooler since they flow better? Or does it not matter?
    -Chris
  6. divorced
    Jul 20, 2004
    5,115
    I don't think they help it run any cooler, nothing noticable on your temp gauge anyway. I just think they sound cool, they give an exhaust system a lot meaner tone.
  7. ntaj*ep
    ntaj*ep 1/2 ton status
    Feb 4, 2002
    3,248
    Evergreen state
    Try-Y headers, run them otherwise run a good cast iron manifold.
  8. juanblzer
    juanblzer 1/2 ton status
    Sep 12, 2001
    1,614
    9
    Chandler, Arizona
    I like quiet rigs when 4wheeling. I don't like super loud exhaust and I like to keep from frying my starter solenoid. Sure you could use a starter solenoid from a ford but I'd rather run manifolds. I don't like the heavy duty shackle conflict when running headers either. But I don't run leafsprings anymore.
  9. divorced
    Jul 20, 2004
    5,115
    My shackle bolt doesn't even come close... /forums/images/graemlins/dunno.gif /forums/images/graemlins/whistling.gif
  10. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    run the headers. why, because they're what you have, and they wont cost you anything. sounds like a good enough reason for me. /forums/images/graemlins/thumb.gif
  11. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    I'd run the headers you have for now. If you want too upgrade, you can always buy yourself a new set of Thorleys.
  12. rcamacho
    rcamacho 1/2 ton status
    Jul 1, 2004
    1,324
    WA
    If you keep the headers you might consider sending them out for ceramic coating after a good bead blast. The coating will keep the temperatures down and inhibit rust through.
  13. dyeager535
    26,982
    191
    I think I'll trade any header concerns (leaky connections from loosened bolts being the most common) for reliability of manifolds any day of the week.
    Manifolds fail too, and as was mentioned, if you ever want to get the pipes off, good luck NOT breaking the exhaust studs on manifolds.
    You can bolt them on and not have problems for a long time (typically) but headers are "free" power, especially if they are already there. +20-40HP on a stock 350 is absolutely the norm with headers over manifolds.
    As cheap as headers are, even for decent ones, I'd run what you have until they rot out, and get another set.
  14. marv_springer
    marv_springer 1/2 ton status
    Aug 3, 2001
    2,781
    Mesa, Arizona
    headers / manifolds
    >5000 rpm - you need headers
    <5000 rpm - I prefer manifolds
    It's that simple! /forums/images/graemlins/laugh.gif
    Marv
  15. Aquaman
    Aquaman 1/2 ton status
    Apr 21, 2002
    337
    Kansas City, MO
    My headers are the reason I am 2wd right now. Switching to manifolds, due to a deminishing wallet. My headers hang down too low now that I dropped her down from 12" susp+3" body to 6" suspension.
  16. swissk5
    swissk5 Registered Member
    Oct 18, 2004
    7
    Switzerland
    I've got an '86 blazer that originally had the 304 engine built in. someone swapped the engine to a 350 but stuck to the original exhaust manifolds. somehow the block that was put in is shorter than the original engine, so the last bolt closest to the passengers feet can't be fastened. there just isn't no block behind the hole anymore... /forums/images/graemlins/yikes.gif
    this leaking makes my blazer sound like a vw beetle.
    so is the '86 something special or is the new engine something special? because i'm thinking about getting thorley headers and would like them to fit..
  17. diesel4me
    Jul 24, 2003
    17,584
    945
    Massachussetts
    Some 305's did have weird bolt patterns on the heads for the exhaust manifolds for a few years---I think they had 5 bolts instead of the usual six,and only on the passenger side(might be wrong about that--havent seen one in a long time!).They had an adapter plate to make headers fit on those heads if I remeber correctly--it might not be available anymore,since there werent that many vehicles with the oddball bolt patterns built.Someone on here has probably run into the same dilema,they can most likely give you some advice about making the manifolds fit--or if not you will have to get a 350 manifold. /forums/images/graemlins/crazy.gif
  18. bigyellowjimmy
    bigyellowjimmy 1/2 ton status
    Jan 15, 2004
    2,105
    Chandler, AZ
    I prefer headers for high RPM and manifolds for low RPM (normal) useage.
  19. swissk5
    Oct 18, 2004
    7
    Switzerland
    thanks alot for that info diesel4me! guess there was one of those weirdo 305's in there before then.. i'll go ahead and just swap the 305 manifolds for 350 thorley headers. /forums/images/graemlins/woot.gif
