headers..what do yall run?
Discussion in 'The Garage' started by broncoman6524, Apr 19, 2007.
  1. broncoman6524
    broncoman6524 1/2 ton status
    Oct 31, 2005
    2,469
    chuluota Fl
    i bought a set of cheap hooker steels. and i think i warped the flange.:doah: (overtightening)
    i know the thicker flange is better (3/8s right) adn the bigger the tubes the more hp sooo if i go with the 1 1/2 primaries that would create more torque correct?
    what material for the actual headers should i use? steel or stainless, and use ceramic coated right?
    lotsa questions but if i end up having to buy another set...i want them to last and work best.
    thanks brothers
  2. wasted wages
    wasted wages 3/4 ton status
    Dec 3, 2003
    9,194
    Dallas Texas
    Hooker Pro Comps:bow:
  3. gmc4cw
    gmc4cw 1/2 ton status GMOTM Winner
    Jul 19, 2006
    3,907
    west chester, Pa
    I have a set of hedmanns now. part number 69230. they are painted steel but you can get the same ones already Jet-Hot coated for $420. they fit great and have a ball flange for the collector. I have pictures in a thread somewhere.
    I ran dynomax before and the collectors hit the shackle bolts. they were coated but the finish didn't last as long as it should. apparently Jet-Hot has an even better coating then the previous one I got.
  4. Chevy305
    Chevy305 6 Lug 14bsf Status Premium Member GMOTM Winner
    Jan 23, 2006
    11,232
    490
    New Hampshire
    Stainless is always the best way to go, but I think that Edelbrok is the only mfg that makes headers out of it. But their headers are the smog legal shorties, no long tubes from them.
  5. broncoman6524
    Oct 31, 2005
    2,469
    chuluota Fl
    [/QUOTE]
    you mean the super comp series?
    i want/need long tubes. i just redid my entire exhaust and its 1 piece collector to tip...so i REALY dont wanna have to do MAJOR mods to it...
  6. 79Beast
    79Beast 1/2 ton status
    Dec 9, 2001
    1,155
    Georgia
    For a long time I ran Flowtech headers from Autozone. They are cheap ($78) and pretty flimsy. They do have a lifetime warranty. I really only had problems with the collector flanges leaking. I found that after installing new header gaskets, it's best to re-tighten after the first three or four heat cycles and at every oil change after that.
  7. k20
    k20 3/4 ton status
    Sep 9, 2001
    5,068
    Mineral Springs, NC
    Thorleys. Ran em on my smallblock, now I run em on my bigblock.
  8. Cricket
    Cricket 3/4 ton status
    Nov 29, 2004
    8,224
    Colorado
    Avoid Dynomax headers, they are more trouble than the savings is worth. My next set will be Doug's or Hooker.
  9. sope
    sope 1/2 ton status
    Jul 8, 2005
    967
    British Columbia
    Cheap Flowtech's with good gaskets.
  10. ryoken
    Jun 13, 2003
    29,624
    1,380
    Jersey Shore
    Hookers are available in stainless, as are Thorleys and Stan's too...
    I've strongly considered the Hooker stainless ones... They run about $600...
  11. BlaKK54Speed
    BlaKK54Speed 1/2 ton status
    Dec 14, 2006
    242
    Omaha, NE
    i have the cheap flowtech's but they work good for me
  12. Chevy305
    Jan 23, 2006
    11,232
    490
    New Hampshire
    Really? I did not know that!! I will have to look them up.
  13. ryoken
    Jun 13, 2003
    29,624
    1,380
    Jersey Shore
    http://www.holley.com/types/Stainless Steel - Vibratory Polished.asp
    Being in the marine biz, I've worked on boats with $5000 sets of headers.. my buddy builds em.. I've seen the benefits of stainless firsthand...
    I'm more than likely doing the SS hookers, just need to figure out if I can run full tubes...
    SS generally will be in $600 to 1000 range.. iirc, Thorleys and Stans versions run in the $900ish range... :eek1: :doah: :eek1:
  14. jtrux
    jtrux 1/2 ton status
    Jan 14, 2007
    185
    San Antonio, TX
    I like Hooker the best, right now I run part number hkr2453 (for 1st gen blazers) and love them. I had both Dynomax and Hedman before these ones and won't go back. Headmans were okay but the Dynomax just plain sucked and never stopped leaking from the day I bought and installed them.
  15. rick88blaze
    rick88blaze 1/2 ton status
    Jan 24, 2003
    2,342
    Knob Noster, Mo.
    I've got Dynomax on mine and haven't had any problems with them really except for the collectors leaking a little. I've had them on there since the fall of '03 now. :D
    Rick
  16. RockinChevy
    RockinChevy 1/2 ton status GMOTM Winner
    May 9, 2005
    2,313
    Chandler, AZ
    I have Hookers on mine but I don't know what model or part #... Came with the Blazer when I bought it. Had no trouble with it since except those damn header bolts backing out.
  17. Yukon Jack
    Yukon Jack 1/2 ton status
    Jul 25, 2002
    1,984
    Rose Hill, KS
    No problem with the Dynomax Ceramacoated headers on my 69 K20
