headers
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 1harley, Jul 25, 2001.
  1. 1harley
    1harley Newbie
    Jul 25, 2001
    Va
    Has anyone had broken bolts/studs when removing the stock exhaust manifolds to install headers? Does the head have to come off if it breaks flush with the head? Are there any tricks-heat, solvent, etc- that make it easier? I'll be amazed if a collector passes the frame & front drive shaft-is this a problem area? The other posts seem to favor Dynomax system-comments?
  2. muddin4fun
    muddin4fun 3/4 ton status
    Feb 19, 2001
    5,644
    N Texas
    Try some PB Nutblaster and let it soak for a little bit. It's not the same as WD-40. It works 100 times better. I haven't had that stuff fail me yet!
    Available at your local parts store or hardware store [​IMG]
    I've got a mind like a . . . a . . . what's that thing called?
    <a target="_blank" href=http://www.geocities.com/muddin4fun79blazer/>http://www.geocities.com/muddin4fun79blazer/</a>
  3. Pugsley
    Pugsley 1/2 ton status
    Jan 16, 2001
    3,556
    Tucson, Arizona
    Like she said - PB Blaster will do it. As for collector clearance, mine (Hedman) went right in with no problems.
    Generic Signature
    <a target="_blank" href=http://pugsley.alloffroad.com>pugsley.alloffroad.com</a>
  4. muddin4fun
    Feb 19, 2001
    5,644
    N Texas
    Oh sorry! I have Heddman and have not problems with the clearance. I think they might be one of the better ones for this problem.
