Headers
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by ONE2PLAY, Feb 12, 2002.
  1. ONE2PLAY
    ONE2PLAY Registered Member
    Oct 2, 2000
    34
    Bakersfield California
    I will be adding headers to my 89 blazer. I'm thinking about horleys. Does anybody agree or disagree with this choice?
  2. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    The doug thorleys are a good header. I have always heard good things about them.
    I am running the Edelbrock TES on my 89. It is pretty similar to the Thorley system with the Y pipe. It has held up real well.
    I put it on 2 years ago and have had no leaks and it still looks almost new.
    <a target="_blank" href=http://coloradok5.com/gallery/Thunders-Blaze> Blazer pics</a>
    <font color=blue>Nevada... Where the pavement ends and the west begins
  3. marv_springer
    marv_springer 1/2 ton status
    Aug 3, 2001
    2,781
    Mesa, Arizona
    I say sell the horley and keep the Blazer!.... : D
    Marv
  4. kpanza
    kpanza 1/2 ton status
    Dec 8, 2000
    1,579
    Lake Forest, Orange County, California
    I have had the Thorleys for about 7 years now...still working great! I have had a couple of gasket leaks over the years, but generally they seal up real nice. Just make it a point to tighten the header bolts every time you change the oil (if they actually need tightening, otherwise just check them). They will last the life of your truck, won't rust apart like some others. They did add some torque also...they are kinda pricey, but when you figure that they will last a long time, you are actually getting a good deal.
    Keith
    So Cal Big Dawgs
    President
  5. ONE2PLAY
    Oct 2, 2000
    34
    Thank-You all.
  6. CaptCrunch
    CaptCrunch 1/2 ton status
    Feb 2, 2001
    3,596
    Minnesota
    The issue with Thorley has alwas been price. They aren't the cheapist, but they are dang good and coated. I'm trying to decide what way to go myself for headers when the new motor goes in. Thorleys, Flowtech afterburners (either coated or non) or Hookers (coated or not) . I think they are quality choices
    -Mikey
    1987 Chevy K5 Blazer- 350 TBI
    <a target="_blank" href=http://coloradok5.com/gallery/captcrunch>http://coloradok5.com/gallery/captcrunch</a>
  7. slider
    slider 1/2 ton status
    May 7, 2001
    547
    Whidbey Is. Washington
    One last header you should look at is made by Stans Headers in Auburn Washington. Web site is www.stans-headers.com
    They use thick flanges on the head and a gasketless style coupler on the collector end. They look chrome plated but its not. They are the best headers I have ever used or seen. They are about the same price as Thorleys. Check them out, you will not be sorry. I love mine
    <P ID="edit"><FONT class="small">Edited by slider on 02/14/02 11:08 PM.</FONT></P>
  8. reddog64
    reddog64 1/2 ton status
    Nov 9, 2000
    3,325
    Federal Way, Washington
    Go Custom...
    My custom stainless steel headers on the 454 cost 665... have a 4 inch collector, and 2 inch pipe for each exhaust port... There purdy...
  9. grumpy
    grumpy 1/2 ton status
    Jan 7, 2001
    353
    San Diego, CA
    Put a dash betwen "stans" and "headers"
  10. 4X4HIGH
    Dec 14, 2001
    22,063
    70
    Pleasanton, CA.
    If you don't mind doing a little grinding on the drivers side frame rail and redoing the front portion of your exhaust and installing the 02 sensor in the y pipe i would choose gibson stainless headers. I used these on my blazer and i love them. I had a 2 1/2 inch Y pipe made that goes into a 3 inch exhaust pipe and high flow cat and then gibson muffler and exits out the drivers side just rear of the tire. I did pick up a tremendous amount of torque and also some mileage. Just my $.02
  11. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Clicky: <a target="_blank" href=http://www.stans-headers.com>www.stans-headers.com</a> [​IMG]
  12. dyeager535
    26,980
    How are they gasketless? They use the same type of flange as the stock manifold on the drivers side? (the cast in "donut" if you will) That would sure be a nice connection.
    Dorian
    My tech/links page: <a target="_blank" href=http://www.dorianyeager.com/index2.html>www.dorianyeager.com/index2.html</a>
    Why insist on counting when the ring gear has the tooth counts stamped in?
  13. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    I have Dynomax coated. They're nice in the cheapo class. I'm sure the Thorleys would put them to shame, but for $200, they're great.
    Tim
  14. CaptCrunch
    Feb 2, 2001
    3,596
    Minnesota
    How has the coating stood up to the good ole rustbelt winter thus far Tim?
    -Mikey
  15. chvyhs
    chvyhs 1/2 ton status
    Feb 12, 2001
    1,469
    Murrieta, California
    How much are the Thorleys?
    <a target="_blank" href=http://community.webshots.com/user/chvyhs>WebShot Pics</a>
    It's a wheelbase thing, you wouldn't understand.
  16. DesertDueler
    DesertDueler 1/2 ton status
    May 23, 2001
    3,106
    Phoenix, AZ
    Edelbrocks are a great headder. Those are the only ones we use on CHevy trucks at work. Never had a problem with them leaking, but the are expensive.
    86Jimmy 4"&35"MTRs,87 burb 4"&33"MT,69Firebird w/525 hp,and 70GTO live in PHX,AZ<a target="_blank" href=http://www.geocities.com/modifierperformance>My vehicles</a>
