headers?
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by shaun, Dec 4, 2003.
  1. shaun
    shaun 1/2 ton status
    Apr 22, 2003
    745
    What are you running? Why? And if you could change what would you recommend. Any opinions will be appreciated. I am looking at some block huggers to replace my hooker comps.
  2. Burt4x4
    Burt4x4 3/4 ton status
    6,854
    California (Modesto area)
    I like Hedmen for my K5.
    I like the way they tuck up nice and high to the frame.
    I was gonna get Thorleys but they hang way too low for my type of wheelin. So I got the Hedmen Elite series fer like 260 from Summit. They have super think flanges and the tubing used is thicker as well. They come with a coating that is aluminum in color and have yet to change color or burn. I like um alot.
    /forums/images/graemlins/thumb.gif
  3. shaun
    Apr 22, 2003
    745
    I was thinking of stainless block huggers for that same reason. It would be easy to tuck the exhaust high up to prevent any rock rash.
  4. ZZ4x4
    ZZ4x4 1/2 ton status
    Oct 17, 2001
    542
    Garland, TX
    I've got the Thorleys and as Mr. Burt stated, they are low which makes them pretty darn close to the passenger side shackle. I didn't have too much choice in headers because I am running aluminum angle plug heads which need extra header clearance for the plug boots. Thorley is the only company I found who advertised they will work with angle heads. The Thorleys also provide great torque due to the Tri-Y design , and look very nice indeedy /forums/images/graemlins/wink.gif.
    Jeff /forums/images/graemlins/usaflag.gif
  5. emoo99
    emoo99 1/2 ton status
    Jan 16, 2003
    494
    Washington
    i'm also runnin the headman elite ceramic coated full legnth headers from summit,, they have really thick flanges, the only problem i found with them is the passenger side collector is about 1/4 inch from the shackle bolt and the driver side rubs a little, if they ever start leaking when i replace the gaskets i'm going to sand down the bolt a tiny bit to solve the problem.. other than that i thing the headders are excellent and i defenetly would reccoment them /forums/images/graemlins/thumb.gif
  6. BobK
    BobK 1/2 ton status
    Oct 5, 2000
    1,604
    Petrolia,Ontario,Canada but working in Port Huron,
    Stock Corvette 2.5" exhaust manifolds.
    Pace Parts sells them.About $129.00 a piece though.
    Click HERE to see them.
    Prob. get a set on E-Bay cheaper.
    I like them just because there are no typical header problems.Just put them on and torque them down.
  7. jasonkh2tg
    jasonkh2tg 1/2 ton status
    Mar 27, 2003
    139
    MPLS MN
    If you gonna run block huggers you will have to grind your cross member....Im going to build a custom cross-member to make way for my block hugger.....If I had to do it all over again 2.5" ram-horn all the way..... cross member with block huggers...
  8. earl87gta
    earl87gta 1/2 ton status
    Apr 6, 2003
    551
    Chuckey TN
    Now Im using 2.5 ram horn but I have a set of SLP Stainless heders that I had got for a 68 firebird but ended up going to a 427 and couldnt use them so now Im thinking abought using them on the K5.
    Earl
  9. Smitty
    Smitty 1/2 ton status
    Sep 1, 2000
    999
    Crestview, FL
    Looks like these would solve the problem of finding headers for the angle plug heads on my 383. Thanks.
  10. earl87gta
    Apr 6, 2003
    551
    Chuckey TN
    I have a set of the tube ones from a 89 vet if you think you can use them Ill try to dig them up. Ill send a pic and just make me an ofer its one of those things I have just in case some one needs them.
    Earl
  11. TONYP
    TONYP 1/2 ton status
    Aug 13, 2002
    2,116
    so cal
    I run Thorleys and love all the bottom end I get from them, then I put on a set of good mufflers and it’s quite…think about having that load exhaust all day long and if you want it rumbling in your ear…if you do get headers, I put these on mine and it’s been almost a year and no leaks…
  12. champsjimmy
    champsjimmy Registered Member
    Nov 5, 2003
    53
    St. John, IN
    Does anyone happen to have a part # for the Hedmans? Summit lists headers for the K-5 application, but they are not the coated ones.
  13. Beast388
    Beast388 1/2 ton status
    Nov 6, 2001
    3,039
    Clinton, IA USA
    Here you go.....P/N 69830 according to Hedman's site /forums/images/graemlins/thumb.gif
  14. Topdown
    Topdown 1/2 ton status
    Nov 26, 2002
    2,598
    Vancouver, Washington, U.S.A
    hedman also makes a set that will fit aluminum angle plug heads that are like $109.00 a set at the local parts place. If your looking for a good header for low buck, those are the ones. I run them now and ran them on my angle plug trick-flow heads in my first gen and never had any problems.
  15. shaun
    Apr 22, 2003
    745
    Earl 87 if you have pics please send me some pics. Will those work on my first gen?
