Headlamp wiring, 76 C-10
Discussion in 'The Garage' started by Capman2k, Nov 16, 2003.
  1. Capman2k
    Capman2k 3/4 ton status
    Jun 22, 2001
    5,070
    dg
    My mom's 76 C-10 has some bad wiring on the driver's side light... It's really dim and sometimes it'll be bright for a minute... She bought a new lamp and I put it in and had the same problems, so I jiggled the wires around and think that's the problem... In some positions the light is bright, and some really dim... How would I go about re-wiring this lamp? I kinda followed the wires and they went into one of those black hose things that keep wires all together, so is this a difficult thing? Could I just cut the wires where they come out of the hose and connect the new wires to that? /forums/images/graemlins/1zhelp.gif
  2. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    Sounds like all you really need to do is splice in new headlamp connectors that plug into the back of the headlamp.
  3. GMCLegacy
    GMCLegacy 1/2 ton status
    Jan 24, 2002
    620
    Grand Haven, MI
    it sounds like there is some corrosion on the terminals that the light bulb plugs into, i do not think it is in the wiring itself.
  4. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    check the grounds and bolt on that side of rad support, also, do soem cleaning on contact areas of wires and metal of the support
