Headlight Adjustment
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Chevit, Nov 28, 2003.
  1. Chevit
    Chevit 1/2 ton status
    Dec 10, 2001
    1,492
    dnaltroP, nogerO
    Anyone have a trick to doing this the proper way? I know if you are off by a few inches at 25 yards you will be way off at 100 yards.
  2. tecton
    tecton 1/2 ton status
    Dec 1, 2002
    1,553
    WV
    count screw turns, lol
  3. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Aim 'em til it looks good.
  4. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    I always use 2 feet(knee height) off the ground at 25 feet /forums/images/graemlins/thumb.gif
  5. Chevit
    Dec 10, 2001
    1,492
    dnaltroP, nogerO
    thanks, how many screw turns is that /forums/images/graemlins/crazy.gif /forums/images/graemlins/crazy.gif j/k /forums/images/graemlins/wink.gif
  6. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    i always adjust them using a garage door, make them same height spots on the door
  7. Chris_T
    Chris_T 1/2 ton status
    Mar 17, 2001
    718
    Saskatoon, SK
    Park somewhere level, shine the lights on a wall measure the height to the middle of the headlight as well as between them. Put the high beams on and adjust until they are more or less dead ahead. Then switch back to low beams. The pattern should go in towards the center and down (2 headlight truck). Now that they're pointing straight ahead you can tinker up and down a bit depending on your truck's lift.
  8. Muddytazz
    Jun 30, 2002
    20,073
    Salem, Or.
    In your case, prolly close to 1000 turns /forums/images/graemlins/shocked.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif j/k /forums/images/graemlins/thumb.gif
  9. Chevit
    Dec 10, 2001
    1,492
    dnaltroP, nogerO
    and would that be clockwise or counter clockwise /forums/images/graemlins/thinking.gif
  10. k5guyva
    k5guyva 1/2 ton status
    Oct 26, 2003
    165
    Southeast VA
    Yes, that would be clockwise or counter clockwise. /forums/images/graemlins/rotfl.gif
  11. Muddytazz
    Jun 30, 2002
    20,073
    Salem, Or.
    /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/thumb.gif
  12. Chevit
    Dec 10, 2001
    1,492
    dnaltroP, nogerO
    but in which order... /forums/images/graemlins/rolleyes.gif /forums/images/graemlins/rolleyes.gif /forums/images/graemlins/rolleyes.gif
  13. jjlaughner
    jjlaughner 3/4 ton status
    Jan 12, 2001
    7,406
    Indiana
    I do the same thing. I get about 10-15 feet back from the garage door and aim them to match heigth on the door. Then back out and shine them down the road, drivers side down the center and passengers side down the ditch. If I can see the cross road 200 feet up I'm happy.
    I'm one of the Dick's that has bright driving lights set for 100 feet out too [​IMG]
  14. k5guyva
    Oct 26, 2003
    165
    Southeast VA
    There are two adjustment screws. The top one controls the up/down. The one on the side controls left/right. You'll find that the side screw is on the side of the truck that the fender is.
    Do as everyone is suggesting. I pull 20 feet from the garage door and take a measuring tape and measure the center of the bulb to the cement floor. Then I measure the beam on the garage door and center the light to be parallel to the vehicle and a couple of inches down (like about 4 inches). You should find when you drive, that it is fairly close. Then fine tune the adjustment and you're done.
    Top adjustment screw moves the beam up when you turn clockwise. The side adjustment screw moves the beam to the outside of the truck when turned clockwise.
    The picture sucks, but that's what you get at midnight.
    /forums/images/graemlins/k5.gif
  15. Can Can
    15,552
    136
    Cochrane, Alberta, Canada
    Good post, brother!!!!! I like to see a guy that goes the extra mile with a pic..... /forums/images/graemlins/thumb.gif
  16. k5guyva
    Oct 26, 2003
    165
    Southeast VA
    Thanks! I really appreciate the comment.
