Headlight Connector
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by daleearnhardt01, Jan 30, 2004.
  1. daleearnhardt01
    daleearnhardt01 1/2 ton status
    Aug 29, 2002
    3,223
    Richmond, VA
    I need a new connector for my low beam on my quad setup. If I cant find one at the parts place can I just use some female spades for now?
  2. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    Yeah you could, or just get one from a junk yard and splice it into the line /forums/images/graemlins/waytogo.gif
  3. daleearnhardt01
    Aug 29, 2002
    3,223
    Richmond, VA
    Maybe you could help me with the problem Muddytazz....
    The ground connecter is kinda melted on the connecter. What would cause the area around the ground part to melt? Never blows fuses or anything.
  4. heavy4x4
    heavy4x4 1/2 ton status
    Aug 28, 2002
    3,270
    Delafield, Wisconsin
    Good luck finding it...I was looking for one a while back and the dealer couldn't even find/get them. (I changed out a burnt-out bulb and the new one wasn't working all the time...turns out it wasn't making contact with the terminals in the connector, but I fixed it by just prying the terminals inward a bit) You could hook the lights up with spades, or, like Tazz said, get one from the junkyard.
    Sorry, can't help you with the ground-terminal-melting problem. /forums/images/graemlins/smirk.gif
  5. daleearnhardt01
    Aug 29, 2002
    3,223
    Richmond, VA
    Well I called the local GM dealer a few months ago and even at wholesale cost (I work at a shop) they wanted 60 bucks...forget that.
  6. Stickseler
    Stickseler 3/4 ton status
    Mar 23, 2001
    6,503
    Northern Virginia
    Spades should work fine..thats what I'm running since I went to H-7's. The spade Ive got are totaly sealed when you put them together, I just use the female side.
    Couldn't tell you why your ground would melt /forums/images/graemlins/confused.gif
  7. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    A loose connection will cause this. When the connection isn't tight, the current for the light is forced to travel through a smaller area of the connector. The current is too much for the small area and causes the metal to get hot, melting the plastic. /forums/images/graemlins/eek.gif I'd scrounge a junkyard for a new connector housing, then get the crimp connectors for the ends of the wires from the GM dealer. That's the only place I know of to get the correct connectors that are designed to lock into the housing. The last time I needed one, for the rear defrost connection on my S-Jimmy, the parts guy just gave it to me. /forums/images/graemlins/thumb.gif
  8. daleearnhardt01
    Aug 29, 2002
    3,223
    Richmond, VA
    What other GM vechicles would have used this same connector?
  9. Stickseler
    Mar 23, 2001
    6,503
    Northern Virginia
    You could goto the parts store and find the bulb # in the book and skim through it thill you see what else uses it. It might even be on the bulb box.
  10. Stickseler
    Mar 23, 2001
    6,503
    Northern Virginia
  11. daleearnhardt01
    Aug 29, 2002
    3,223
    Richmond, VA
    I went the cheap and easy route for now....female spades. /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif
  12. dyeager535
    26,975
    They used 4 headlight setups on the 80's Monte Carlo's and Cutlass, but I don't know that they were wired up the same as the trucks. (both plugs might be two prong)
  13. moneypit
    moneypit 1/2 ton status
    Sep 3, 2000
    1,382
    COLORADO
    I think I still have a few if u need em....I haven't thrown the trash away yet. /forums/images/graemlins/grin.gif
