Headlight Conversion Kit issues
Discussion in 'The Garage' started by dallassnowman, Aug 11, 2005.
  1. dallassnowman
    dallassnowman 1/2 ton status
    Sep 14, 2003
    339
    Forney, Texas
    I recently bought and installed the pilot conversion kit. It uses H4/9003 bulbs.
    I put 9003 Phillips High visibility bulbs in. The problem is on low beam they are very dim, not hardley even on. But on high beam they are as bright as the old sealed beam...
    Did I buy the wrong bulbs?? or is there another issue?? :confused:
    Now I cannot get my high beams to turn off. I have the 4 light system.
  2. nc87k5
    nc87k5 3/4 ton status
    Sep 23, 2003
    5,231
    North Carolina
    I did a search for you and came up with the search page results and this page. from what I can tell on the second page I gave you, you may need to install some relays. I'm not sure but trying to help.
  3. mouse
    mouse 1/2 ton status
    Nov 10, 2003
    1,448
    Great Falls Mt
    My first thought was that you need to run relays. The problems you have may be a result in running too much current through the stock wiring. Please post up how you have them wired.
  4. dallassnowman
    Sep 14, 2003
    339
    Forney, Texas
    Actually I just plugged them into the stock plug...It is the same as the sealed beam plug.
  5. rocknutah
    rocknutah Registered Member
    Feb 7, 2005
    61
    slc utah
    Lights Camera
    K.C has a quad beam relay kit. It allows you to keep the low beams on when you kick up the high beams. Part # for my 91 burb was #6314.
