Headlight Conversion Wiring Harness Question
Discussion in 'The Garage' started by mr_clean, Apr 18, 2005.
  1. mr_clean
    mr_clean 1/2 ton status
    Sep 21, 2003
    348
    Sacramento, CA
    I'm gathering up the parts to do my headlight conversion and was hoping someone could tell me the difference between the painless wiring kit, APC kit, and the Summit brand kit? I can only find specs on the painless kit, but it may not be worth $50 more...
    Painless is $78
    APC is $46
    Summit is $30
    Thanks,
    Scott.
  2. DPI
    DPI 1/2 ton status
    Jun 22, 2000
    2,792
    In the Burbs close to Tulsa, OK
    You can build your own using this diagram. Just buy some relays and heavier than stock wire. You can get your relays here.
  3. mr_clean
    Sep 21, 2003
    348
    Sacramento, CA
    DANG!!! At $2 a relay I may just do that myself!!!
    Thanks for the tip!
