Headlight Conversion
Discussion in 'The Garage' started by Disturban, Mar 27, 2007.
  1. Disturban
    Disturban 1/2 ton status
    Mar 9, 2006
    120
    Phx,Az
    Has anyone had any luck finding a kit and xenon type bulbs that will work with the 4 headlight system??? I ordered a conversion kit from the almighty JC Whitney , only to find out I couldn't get the right bulb setup.I really like the look and brightness,I'd like to work this out.:confused:
  2. k20
    k20 3/4 ton status
    Sep 9, 2001
    5,068
    Mineral Springs, NC
    http://www.rallylights.com/hella/165mm_lo.asp is what I have on mine. Its an H4 conversion, excellent lighting. I still have the stock 60/55 & 55w bulbs in mine.
    You can swap in Xenon bulbs if you so wish, but HID is a whole different, and more expensive, animal. Alot of people get Xenon and HID confused. Xenon is more or less an HID lookalike.
  3. Disturban
    Mar 9, 2006
    120
    Phx,Az
    sweet!! thx tons, that was really frustrating.Everyone I spoke with wouldn't ( couldn't ) help because of the custom application.Those look great!!
  4. k20
    k20 3/4 ton status
    Sep 9, 2001
    5,068
    Mineral Springs, NC
    No problem man, H65451 should be the part number you need for your app, and itll come with 4 housings, 4 bulbs, and as I recall 2 adapter harnesses. While you are at it, I would recommend going ahead and doin the relay mod. You can either wire it all up yourself, or order the harness & relays from LMC. Its a plug & play deal.
  5. Disturban
    Mar 9, 2006
    120
    Phx,Az
    got the lights and the harness....WOW !!! they're great, thx a ton ! What a HUGE difference.
