headlight flicker?
Discussion in 'The Garage' started by fordslayer383, Mar 4, 2005.
    i noticed today that my headlights flicker what causes this/ symptoms?
  1. big jimmy 91
    big jimmy 91 1/2 ton status
    Feb 21, 2004
    639
    Northwestern Ontario Canada
    Start with connections and grounds , corrosion is a bugger
    Ater that , switch mabey??
    Good luck
  2. darkshadow
    darkshadow 1 ton status
    Dec 6, 2003
    12,250
    C-eh-N-eh-D-eh
    each sockit you head lights plug into have there own ground the black wire comeing off the back ot the light trace that make sure its clean and makeing good contact.
    another question is when do they flicker? all the time when drivein only what you hit bumps?
  3. when im idling! thy dim thn get bright
  4. dyeager535
    26,975
    Check your alternator output with a voltmeter. PROBABLY indicates that the voltage regulator is starting to go. Should be visible in the trucks volt gage as well.
  5. darkshadow
    Dec 6, 2003
    12,250
    C-eh-N-eh-D-eh
    yup i agree, a flicker would be more of a rappid cutting out and on
    as you idle you moters rps change a bit and the regulator is supost to compinsat for this, if your's is not watch out, this can also make too much power witch can kill stuff.
    if you have a hanes or chiltons, it should show how to chech the regulator by by passing it and checking the volts
  6. Ryan B.
    Jul 18, 2001
    5,693
    CA
    My Bass Amp causes this. :grin:
    *Ba BOOM BOOM* = *Dim Dim*
  7. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    hmmm, isnt he the same guy that said he loved to blare SLayer while on the trail?:confused:
