Headlight Fuse
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Bear Creek, Aug 8, 2001.
  1. Bear Creek
    Bear Creek Registered Member
    Aug 8, 2001
    8
    Southport North Carolina
    The headlights failed on my '79 K5. The problem turned out to be a broken wire at a splice near the starter terminal. I tracing out the wiring I did not see any Fuse protection. Does anyone know where it is located? I can splice a new piece of wire onto the leads, but first I would like to know if I am bypassing a fuseable link or if some other form of protection is used.
  2. beater74
    beater74 1/2 ton status
    May 29, 2001
    1,749
    atlanta
    that should pass through your fuse panel but i'm not 100% sure
  3. Bear Creek
    Aug 8, 2001
    8
    I have not been able to find a electrical drawing for it. There is not a fuse in the box labeled headlights. The largest fuse is a 25 amp. There is two 30 amp circuit breakers. One is label A/C the other is marked ACC. I am going to look some more tonight to see if I can trace the wires out.
  4. Pugsley
    Pugsley 1/2 ton status
    Jan 16, 2001
    3,556
    Tucson, Arizona
    If I remember right, the headlights are protected by the "ACC" breaker.
    Dos mas Tecates!!!
    <a target="_blank" href=http://pugsley.alloffroad.com>pugsley.alloffroad.com</a>
  5. Bear Creek
    Aug 8, 2001
    8
    I'll ohm it out to the broken wires to see if it is the right one. I tried to remove it last night but it didn't want to come out. Do these unplug like the fuses? Thanks for your help.
  6. Pugsley
    Jan 16, 2001
    3,556
    Tucson, Arizona
    They are supposed to pop out like a fuse, but are typically tighter - I usually give them a little persuasion with a pair of needlenoses.
    Dos mas Tecates!!!
  7. Michael
    Michael 1/2 ton status
    1,576
    Sherman, Texas
    The headlight switch has a "thermal overload" built into it. It resets after cooling off.....if the current draw is back to normal
    Michael[​IMG]
    <a target="_blank" href=http://www.jmartin.net/parker/goose.htm>www.jmartin.net/parker/goose.htm</a>
