Headlight help
Discussion in 'The Garage' started by Chrisblazzer89, Mar 24, 2007.
  1. Chrisblazzer89
    Chrisblazzer89 1/2 ton status
    Oct 12, 2006
    1,966
    Massachusetts 02301
    Ok I have an 88 K5 and my head lights are acting funny. When I turn them on the driver side lowbeam light is really dim, the passenger side low is fine, and for some reason the passenger side high beam stays on dim with just the low beams. Oh yea and when i turn the high beams on the passenger low beam go off so then im stuck with 3 lights on high. Any one know what could be the problem? I have the stock lights just look at my avatar.
  2. Chrisblazzer89
    Oct 12, 2006
    1,966
    Massachusetts 02301
  3. jpdrake
    jpdrake 1/2 ton status
    Oct 31, 2005
    381
    mass/ cape cod
    had a simaler problem if i touched the brake the head lights came on. my old man had but the wrong bulbs in. id check every bulb b/c i think they all are connected. and i also found ground wires that had rusted off. that electrical stuff is a real bi*%!
  4. Slapperbar
    Slapperbar Retired Navy NDT Examiner Premium Member
    Nov 29, 2005
    2,747
    3
    Harrison City, Pennsylvania
    Check your grounds.
  5. AZ79K5Project
    AZ79K5Project 1/2 ton status
    Jan 15, 2006
    2,082
    Arizona
    x2
    Just upgraded my headlights and wiring. The factory wiring was in really bad shape. A whole lot of corrosion. Who would think that 28 year old wiring would have problems?
